![]() | Home > Puma (Tdci) > Clutch or not to Clutch is that the noise? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2137 ![]() ![]() |
Lof, Transit 4x4, and clutchfix clutch’s all have their fans on here ahead of the gen landrover offering. But while you are in there you need to have the output shaft checked for wear and replaced if needed. Greased versions from landrover or updated version from Ashcroft or more radical one piece solution from Lof are available.
PMU Member Since: 13 Aug 2020 Location: Essex Posts: 33 ![]() ![]() ![]() |
Thanks IanH
Benrlelliott Member Since: 29 Dec 2020 Location: London Posts: 25 ![]() ![]() ![]() |
This may be a option too:
https://www.defender2.net/forum/post542347.html |
Thanks, more food for thought !
