Home > Expedition & Overland > An Anorak's Expedition Trailer
Page 12 of 12 <123 ... 101112
Mo Murphy
It looks fantastic ! Glad it towed well and made all that work worthwhile.
50 Shades of Pennine Grey
Post #1043889 26th Aug 2024 9:39am
Thanks, Mo. I am pretty chuffed Smile Darren
Post #1043920 26th Aug 2024 4:35pm
Winterising
Circumstances mean we won't get to use the trailer again for a while so I've begun the task of winterising it. The first job is to put it on axle stands to save the tyres from getting flat spots. It's easy enough as the thing had two jacks built into the rear legs.
The second job is to drain the water system, which I'm keen to do properly given the trials with the heater and filter described above!
With the trailer slightly nose down, the main water tank is drained from a valve on the front LH corner:
Next was draining the water heater. There's a ball-o-fix valve projecting from the underside of the casing but I made up a drain pipe to direct the water out of the locker, which comprised a barbed fitting and some plastic pipe. Whilst I was at it, I then installed some spring clips to the wall of the locker to store that pipe for future use:
Finally, so as not to be caught out again, I removed the plastic strainer bowl:
All that remains now is to fit the winter cover but I'll wait until the new tent cover arrives from Tuff-Trek before doing so, which should be in a couple of weeks. Darren
Post #1044452 1st Sep 2024 8:36am
One other little job that I've completed is to make/install some fixings for the level and brace for the rear legs. These live in the battery locker, which contains all of things that are needed when setting up.
The construction of the new battery box left a slot along the front edge, into which I stuffed these two items. I wanted to stop them sliding around though, so I made a small ali bracket to retain the level and fitted some spring clips for the brace:
 Darren
Post #1044453 1st Sep 2024 8:42am
L110CDL
Shame you won't be able to use the trailer for a little while but at least you have done the maiden run and sorted out some issue's and then roll on till the next time you can use it again Thumbs Up Clayton.
Keeper.
Post #1044602 2nd Sep 2024 7:40pm
