Home > Maintenance & Modifications > Owners of Nugget Stuff Airbox - Modification
Bluest
I’m thinking of replacing the the M6 bolts that secure the lid with thumbscrews like these: https://www.ebay.co.uk/itm/M3-M4-M5-M6-M8-...635-2958-0
I want to be able to check and replace the air filter without needing tools. Any reason why this is a bad idea? 2007 110 TDCi Station Wagon XS
Post #920079 5th Sep 2021 10:47am
markb110
Can’t see a reason why not. It’s not as if you have to crank the original bolts down really hard.
So if it makes life easy I am all for it.
Thumbs Up
Post #920089 5th Sep 2021 11:30am
Bluest
👍 I shall proceed and report back 2007 110 TDCi Station Wagon XS
Post #920196 6th Sep 2021 9:24am
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Did u ever try this? Curious how it does
Post #935340 28th Dec 2021 5:15am
Bluest
I didn’t, but I will next time the filter is due a change. 2007 110 TDCi Station Wagon XS
Post #935347 28th Dec 2021 8:32am
big110
Has anyone done this fitting of nuggets box on a LHD defender?
Post #935468 29th Dec 2021 12:30am
Unless you definitely know what type you want, then this website has a good range of various grips, screws, knobs, clamps...
https://www.goodhanduk.co.uk/
A cam lever might give an extra level of security?
https://www.goodhanduk.co.uk/Catalogue/Sta...Cam-Levers
Post #935481 29th Dec 2021 9:07am
X4SKP
 SKIP
Post #935504 29th Dec 2021 11:38am
big110
I’ve watched that vid a few times but it still doesn’t help me understand how the flex tube is routed under the heater box. It’s a tiny little space but I can’t see the flex tube fitting through it without misshaping it
Post #935667 30th Dec 2021 4:50pm
Fiebre
Spain 2008 Defender 90 Puma 2.4 SW Java Black
LHD Nugget stuff Air Intake
Hi!! I mounted it on my PUMA LHD!!
But I have not take pictures during the operation, Sad it was not easy but feasible.
The allocation for the tube of nugget is not so big and you will need to use some "lubrication" to connect the plenum with the air box through the arch wheel.
The most possible you will need to dismount the plastic grille in the top of the offside wing and the heater tube to facilitate the nugget's tube allocation and connect with the plenum.
Post #935881 1st Jan 2022 4:05pm
