Home > Maintenance & Modifications > Owners of Nugget Stuff Airbox - Modification |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4217 |
I’m thinking of replacing the the M6 bolts that secure the lid with thumbscrews like these: https://www.ebay.co.uk/itm/M3-M4-M5-M6-M8-...635-2958-0
I want to be able to check and replace the air filter without needing tools. Any reason why this is a bad idea? 2007 110 TDCi Station Wagon XS Last edited by Bluest on 27th Jun 2022 10:35am. Edited 1 time in total |
5th Sep 2021 10:47am |
👍 I shall proceed and report back 2007 110 TDCi Station Wagon XS
6th Sep 2021 9:24am |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
Did u ever try this? Curious how it does
28th Dec 2021 5:15am |
I didn’t, but I will next time the filter is due a change. 2007 110 TDCi Station Wagon XS
28th Dec 2021 8:32am |
Has anyone done this fitting of nuggets box on a LHD defender?
29th Dec 2021 12:30am |
Unless you definitely know what type you want, then this website has a good range of various grips, screws, knobs, clamps...
https://www.goodhanduk.co.uk/ A cam lever might give an extra level of security? https://www.goodhanduk.co.uk/Catalogue/Sta...Cam-Levers Click image to enlarge |
29th Dec 2021 9:07am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
SKIP https://www.defender2.net/forum/topic83242.html |
29th Dec 2021 11:38am |
I’ve watched that vid a few times but it still doesn’t help me understand how the flex tube is routed under the heater box. It’s a tiny little space but I can’t see the flex tube fitting through it without misshaping it
30th Dec 2021 4:50pm |
Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 23 |
Hi!! I mounted it on my PUMA LHD!!
But I have not take pictures during the operation, it was not easy but feasible. The allocation for the tube of nugget is not so big and you will need to use some "lubrication" to connect the plenum with the air box through the arch wheel. The most possible you will need to dismount the plastic grille in the top of the offside wing and the heater tube to facilitate the nugget's tube allocation and connect with the plenum. |
1st Jan 2022 4:05pm |
