Home > Puma (Tdci) > Loss of power and black smoke
KMBXXX
United Kingdom 2010 Defender 90 Puma 2.4 HT Santorini Black
I posted on the Forum about a year ago when my Defender (2.4 Puma) was struggling to pass it’s MOT because of emissions. It passed (just) in the end but in the last couple of months it has gone bad on me. Can anyone help?
Symptoms
When I change up a gear, especially in the low gears, there is a puff of black smoke.
When I am driving under load (usually going uphill on a main road or motorway) I regularly get a power failure. I change down a gear, there is a puff (cloud?) of black smoke and the fault clears.
When the power failure starts there is a rapid increase in the water temperature gauge reading that falls equally rapidly when the fault clears.
There are no engine management faults showing.
The following parts have been replaced in the last 15,000 miles. Turbo, EGR, injectors, fuel pump solenoid and fuel rail valve. I paid for this work to be done so I assume ……... Last week it was pressure tested and the intercooler and hoses did not leak.
It has done 97k miles. Any idea what it could be?
Post #918005 20th Aug 2021 3:43pm
jst
Std map? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918072 20th Aug 2021 11:55pm
Ianh
Potentially vcv, but could be head gasket.
Worth a read and conclusion at end https://www.defender2.net/forum/topic75278...ead+gasket
Post #918075 21st Aug 2021 1:03am
Dinnu
Black smoke is a sign of excess fuel, or air starvation.
I guess the obvious change of air cleaner already done.
Could be the MAF and/or MAP sensor reading incorrect flow and/or pressure leading to excess fuel?
Keep in mind that the exhaust pipe could still be excessively contaminated with sooth, hence the black puffs.
2.4 has the catalytic, worth checking if that is blocked.
The EGRs tend to contaminate the intake with a mixture of oily sooth that can restrict the airflow into the engine. Worth taking the inlet manifold out for checking and cleaning. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #918077 21st Aug 2021 6:37am
Ianh
I would have expected the maf or map to have triggered a Diagnostic Trouble Code and the OP said none were showing.
A vcv issue won’t trigger a DTC but will produce issues with fueling, however that sudden rise in temp in high gear on a motorway incline, I.e under load, and then the temp drop when load off and in 5th has all the signs experienced by Greyman110 in the link I provided. Not something I expect you wanted to hear but does sound very similar to the issues Greyman110 experienced due to a head gasket fault.
A check could be to see if the coolant system is pressurised beyond what is normal, i.e cap releasing pressure, hoses staying hard as per greyman110’s posts in the link.
Post #918093 21st Aug 2021 10:27am
jst
is it an actual increase in engine temp with the gauge going up or the gauge going up to show a fault as its used as an indicator for that too.- would be interesting to know. for the latter the gauge shoots straight to the top. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918112 21st Aug 2021 2:15pm
KMBXXX
Some good responses here. Taking them in order:
JST. It is std map. The temperature gauge is not showing actual water temperature. The rate at which it rises (and especially falls) proves that it isn't the actual temperature of the water. The fan often comes on when the engine is idling and the vehicle is stationary. I thought this was because there was no air flow across the radiator. Have I misunderstood this?
Ianh. Is the vcv what I referred to as the fuel rail valve? If so then when they coded in the injectors they had trouble because of it and told me that they changed it. Could they have used a 'spare' to do the coding and then put the old one back? Let's hope it isn't a head gasket problem. I will read the the greyman post this evening with a glass(es) of wine to soften any bad news.
Dinnu. The air cleaner is in good condition. Having thought more about it, I am hoping it is either the MAF/MAP sensor. It used to occasionally throw up a fault when I accelerated at high speed (well 50 - 60mph) but that fault disappeared when I had the turbo changed. If either of these sensors are sending gibberish to the ecu under certain conditions then the ecu will not necessarily think it is faulty but just respond to the gibberish message. Why should it register a fault if the sensors are talking to it? Is this possible?
The exhaust pipe is pretty sooty and the catalytic convertor needs checking because it must have been abused with the filth passing through it. My view is that this a result of the problem and not the cause. Tell me if you think I am wrong.
Thanks for all your help so far. Any further thoughts are welcome and I will keep you guys posted on what happens.
Post #918122 21st Aug 2021 3:37pm
Ianh
Post #918141 21st Aug 2021 7:42pm
Change the MAF and VCV, the latter doesn’t need programming in.
These two have a big effect on fuelling, and the MAP a lesser degree (boost) but still valid.
Ideally change all three as at that milage it is needed, mine has all three of these items replaced.
Ford parts MAF, PFJones VCV and Bosch MAP and you won’t go wrong and for a good price.
Hopefully it’s nothing more touch wood, but even at worst case scenario these parts aren’t ridiculously expensive and need replacing anyway.
There are details regarding part numbers on here that I have put up in the past.
The biggest problems I ever experienced in mines behaviour was clutch switch problems and VCV going under.
Black smoke is typically over fuelling as a rule, head gasket might be an issue worst case but that’s beyond my scope of knowledge and don’t mind admitting it.
With VCV issues you often get a poor idle as well, but mainly only noticeable in deep winter cold weather and poor performance when really cold say under 4.C and freezing.
Hope that helps, LR parts for these items simply has a ridiculous mark up.
The items are of equal quality, the LR MAP for example is a Bosch part anyway…
The 2.4 motor is a Ford Motor parts engine.
Good luck. 👍🏻 WeWillWin🇬🇧🇺🇸
Post #918146 21st Aug 2021 9:01pm
Millers fuel additive will help your cause too to use permanently if you don’t already.
I’m really happy with it, and many diesel techs recommend it for internal engine cleanliness long term.
Should help bring emissions down a bit too in the process WeWillWin🇬🇧🇺🇸
Post #918147 21st Aug 2021 9:25pm
110CSW
United Kingdom 2007 Defender 110 Puma 2.2 CSW Bronze Green
Hello - same issues with mine - did you get a solution?
Post #1002040 27th Jul 2023 9:02pm
