Home > Puma (Tdci) > Complete bush kit - genuine vs superpro and what’s in a se
Page 2 of 3 <123>
Gasket
Just for completeness.
I confirmed all the part numbers and quantities and made a list of the genuine parts prices. I also checked the contents of the superpro kits and found that quite a lot of the bushes had to be bought separately. The price of genuine vs superpro is basically the same.
Post #917340 17th Aug 2021 1:13am
geobloke
Gasket wrote:
Before I click through on my order, could I ask one more question? I intend to keep the suspension (springs/dampers) completely stock. As such, is there any downside to using Superpro bushes with standard suspension - its not going to rattle my teeth out or anything like that is it?
None whatsoever. Just completed swapping out my 10/12 year old SuperPro bushes this morning, replacing them with... SuperPro bushes Rolling Eyes No wheels left the ground. Miffy hasn't felt so good in at least a couple of years, I will definitely not be leaving it so long next time. Thumbs Up
This is the SuperPro parts list for a post 2002 Defender:
As above the cheapest place to buy them at the moment is Recovery4x4.co.uk and hunt around for the bolt kits as the price does vary.
Post #917558 18th Aug 2021 3:07pm
Gasket
Ace! thank you very much.
I'll get ordering. Just wish they did a bump stop too (if only for aesthetics to match the rest)
Post #917562 18th Aug 2021 3:35pm
hank
geobloke wrote:
You will also need the bolt kit for your year as well and for this Britpart do handy kits that are excellent quality. For a post 2002 Defender 110 these are:
DA7208 Rear kit
DA7204 Front kit
Great info - ordered > 110 XS Double Cab
Post #917700 19th Aug 2021 11:31am
geobloke
There is some more info on the installation in this thread - https://www.defender2.net/forum/topic53859-225.html
Miffy is very much appreciating riding on new bushes, what a difference Smile
Post #917707 19th Aug 2021 11:52am
Gasket
Thanks again for that link - really good write up and has sold me on them.
I've just ordered them now, main set from Recovery4x4 and all the rest from Paddocks.
My only convern is the ARB bushes that I've ordered.
I've measured my front ARB at 25.5mm dia and the rear at 19.5mm dia. I did have to scrape off some dinitrol to get to that measurements so there's still a chance they're slightly over. But while the ARB bushes ordered from Paddocks do include a note saying they correspond to the LR part numbers (NTC6828 and EGP1889), they also have the internal diameters listed as 25 and 18mm - I just hope they're right as I do know that Superpro offer this part with a number of different internal diameters - I'll get out there with a bit of emery cloth to double check.
Post #917778 19th Aug 2021 4:17pm
geobloke
Super Thumbs Up Honestly I do not think you will be disappointed, I know I ma not. I also have the ARB bushes as well and they fit perfectly, or at least the front pair do. I have the X-Deflex ARB on the rear which has a much chunkier piece of metal, c.25mm or so.
It is funny but having just got back from a quick drive out to the woodlands for a dog walk I realised that the marginally concerning clonk I had thought was a transmission clonk seems to have been in fact worn bushes. No clonks no rattles and Miffy feels like she's as light as a feather in the corners Thumbs Up
If you have standard LR bushes installed at the moment and I am sure you said you did, be prepared to drill out the rubber, push out the centre metal sleeve, then with a hack saw cut slots in the outer sleeve. Use a chisel to bend the sleeve inwards, then tap the remainder out with a suitably sized socket on an extension. It's the easiest way I have found to do this DIY style.Do not bother with burning the rubber out it takes too much time and stinks. Drilling is the way to do it. Unless you have a press that is Rolling Eyes
The only thing that may slow you down is if the bolts have rusted to the inner sleeves of the bushes. To get these out you will need an angle grinder with a thin slitting disc. Protective glasses etc are essential, but there is enough space to cut the radius arms or trailing arms out of the axles. After that it is as above and when fitting the SuperPro bushes grease is you friend. Use the supplied grease for the bushes and copper slip for the threads and bolts.
Thumbs Up
Post #917783 19th Aug 2021 4:41pm
Gasket
Thanks buddy.
Its actually being done for me - hence me being so pedantic about parts and part numbers (I'm supplying the kit and you know it'll be a drama if the garage come to fit it and its wrong). The 90 is going in to have the chassis and all underpinnings removed, blasted, galved (where possible) and resprayed. I'm getting the suspension done at no labour cost given they're going to have to remove the (yes, you're right, factory) bushes anyway.
I've just double checked and my rear, factory, ARB is definitely 20mm (or a hair underneath) - so the 18mm rear bush is going to be too tight. As well as the one that's advertised as being a direct replacement for EGP1889, the superpro part number SPF1697-18K, they also do the same bush in 19mm and 20mm diameters - thought these aren't stocked at most LR places so its all a bit odd: can't be the first person to have found this.
Post #917796 19th Aug 2021 5:25pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Did you end up going the SuperPro bushes Gasket? If so, what do you think of them?
A couple of my bushes were flagged as starting to feel a bit tired at the MOT last year and with the next MOT rapidly approaching, I think I need to bite the bullet and sort them out. 2011 CSW XS 90
Post #990167 24th Apr 2023 12:08pm
Gasket
I didn't in the end.
I bought them all and supplied them to the garage doing the work, but on drop off day the technicians all made a face and said they didn't rate polybushes of any description. Rather than argue the point, I took them back, sold them and bought a complete set of genuine bushes instead.
I'll still be using Superpro bushes on my other builds, but wasn't worth arguing as inevitably if I had any snags after they finished the work, I'm sure a way would have been found to blame my insistance on the bushes Laughing
Post #990175 24th Apr 2023 12:41pm
SJM2018
Yea that's fair enough.
I generally always buy genuine (or end up buying genuine after getting stung by Britpart for the 1000th time and swearing to never buy from them again), but when you see the likes of Glynn Lewis saying they're better than "genuine" stuff that's now available, it does make you think.
Thank you for the reply Thumbs Up 2011 CSW XS 90
Post #990177 24th Apr 2023 12:50pm
kenzle8a
It’s a shame that garage’s are ignorant to quality aftermarket products. I’ve used superpro on all of my cars, vastly superior to the oem items.
Post #990233 24th Apr 2023 9:43pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
lord-h I concur
Superpro fitted 30,000 miles ago almost throughout on my 14plate (all but the antiroll bar bushes), but what a Censored it was to get the originals out lucky I had access to 30t press,
Handling is fantastic running i'm running on muds, steering wheel completely stable (no shaking) at motorway speeds
I for one will not be refitting original
Post #990241 25th Apr 2023 7:04am
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
I just loaded a full set of OEM bushes into my shopping cart but a the last moment I thought I'd browse the bank of knowledge that this forum represents.
The question I was originally pondering was if my assumption that my original bushes are near end of life is correct? The girl is 18 years old this year and I assume she never had new bushes. I don't have the experience to judge a bad bush from a good one. It couldn't hurt to replace them, could it? I'd like to do preventive maintenance where it makes sense and this seemed like such an area.
I was not surprised to see that opinions where split between different makes of bushes but it was a bit concerning that the original quality was no longer to be found. I'll probably stick to OEM quality anyways.
Post #1063376 20th Mar 2025 9:41am
Mo Murphy
Beware OEM is not genuine Land Rover and will be short lived. If you want rubber bushes buy only genuine directly from Land Rover.
50 Shades of Pennine Grey
Post #1063382 20th Mar 2025 10:44am
Page 2 of 3 <123>
