![]() | Home > Puma (Tdci) > Complete bush kit - genuine vs superpro and what’s in a se |
fogbank Member Since: 30 May 2024 Location: Daylight Savings Posts: 13 ![]() ![]() |
I’d only ever fit superpro now, vastly better than OEM and will last longer.
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 63 ![]() ![]() ![]() |
Good thing I asked.
![]() ![]() I was worried of the comments about poly bushes wearing on the arms but guess it's a risk I need to take then. Thanks for the replies! |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
what replacements did you use? I'm replacing the front ones (panhard and front radius arms) and I've a shopping cart ready for genuine LR ones. I understand quality has decreased, but 2 years? ![]() Also, anyone knows how can I check the compatibility of polybush when the add states "9A7689367 ONWARDS" ? What chassis or year is this? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 209 ![]() ![]() ![]() |
That would be 2009MY vehicles with the last 6 digits showing as the chassis number onwards.
At this time the A frame bushes changed to ANR4164 which use a metric bolt. LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
Thanks!
![]() I was confused because my chassis is 8AA793*** and that 9A7689367 wasn't making much sense. Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Your year code is "AA" - indicating a 2010 model year.
This is AFTER the "9A7689367". You want the "9A7689367 onwards" version. You need to read the final 8 characters of the VIN. ![]() ![]() |
