Home > Td5 > Rear chassis shock mounts
excossack
Were the rear shock absorber mounts attach to the chassis, are there supporting/crush tubes in the chassis that the bolts pass through or is it just open chassis? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #914387 28th Jul 2021 7:36am
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
I think they way be open there replaced mine a while ago and don’t remember any tubes there
Post #914422 28th Jul 2021 12:04pm
excossack
Cheers Si. 1999 Defender TD5 110
Regards
John M0VAZ
Post #914423 28th Jul 2021 12:07pm
dailysleaze
Mine has v-formed channels inside, rather than actual tubes but in practice yes there should be
Post #914450 28th Jul 2021 2:48pm
excossack
Cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #914464 28th Jul 2021 3:50pm
Dinnu
Indeed, there should be U shaped channels very close to the holes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #914470 28th Jul 2021 4:25pm
Retroanaconda
Indeed. Plus reinforcing C-channels top and bottom within the chassis rail, these extent through the whole rear section around the spring/shock mount.
Some of it visible here through the rear crossmember.
Post #914489 28th Jul 2021 6:00pm
rallysteve
Is that a genuine chassis? 02' 110 TD5 Double Cab Rebuild Thread
Post #914492 28th Jul 2021 6:29pm
Retroanaconda
A Marsland one so not sourced via Land Rover but the same GKN chassis as a genuine one yes.
Post #914493 28th Jul 2021 6:36pm
excossack
Thanks for the picture. Good to know there is some reinforcement in the area. 1999 Defender TD5 110
Regards
John M0VAZ
Post #914496 28th Jul 2021 6:52pm
Dinnu
On Td5 (not sure if all years) and later, the angle iron reinforcements are all along both top sides of the chassis (for sure on a 90). Should be able to see the spot welds from the outside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #914503 28th Jul 2021 7:33pm
