![]() | Home > Td5 > Rear chassis shock mounts |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
I think they way be open there replaced mine a while ago and don’t remember any tubes there
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5941 ![]() ![]() ![]() |
Cheers Si. 1999 Defender TD5 110
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
Mine has v-formed channels inside, rather than actual tubes but in practice yes there should be
Cheers 1999 Defender TD5 110
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3537 ![]() ![]() ![]() |
Indeed, there should be U shaped channels very close to the holes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2735 ![]() ![]() |
Indeed. Plus reinforcing C-channels top and bottom within the chassis rail, these extent through the whole rear section around the spring/shock mount.
Some of it visible here through the rear crossmember. ![]() Click image to enlarge |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Is that a genuine chassis? 02' 110 TD5 Double Cab Rebuild Thread
A Marsland one so not sourced via Land Rover but the same GKN chassis as a genuine one yes.
Thanks for the picture. Good to know there is some reinforcement in the area. 1999 Defender TD5 110
On Td5 (not sure if all years) and later, the angle iron reinforcements are all along both top sides of the chassis (for sure on a 90). Should be able to see the spot welds from the outside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
