![]() | Home > Maintenance & Modifications > Cleaning Recommendations Please |
Alun Member Since: 22 Dec 2015 Location: Snowdonia Posts: 39 ![]() ![]() ![]() |
Can anyone recommend a cleaning approach to removing the film that's built up on my black Defender? It has a galvanised hardtop which has "leeched" onto the paintwork shown in the photos
Thanks in advance for any help or pointers ![]() Click image to enlarge ![]() Click image to enlarge |
Griff90bowler Member Since: 24 Feb 2021 Location: Cowbridge Posts: 134 ![]() ![]() |
Red 7 👍
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2182 ![]() ![]() |
Do a smal test area first, but my recommendation would be :-
Try bilt hamber korrosol https://bilthamber.com/product/korrosol/ Give it a wash and dry , Followed by a clay bar Then use farecla G3 regular grade paste compound. https://www.farecla.com/products/g3-regula...pound/%5B/ Use a slightly damp microfibre cloth to apply in small areas at a time and add a little spray of water as the paste drys to keep the paste working. Moving the cloth up and down and side to side then in a random circular motion to finish. Then use a standard polish over the top in the same way, then buff with a different microfibre cloth. Clays, polish and wax here https://bilthamber.com/product-category/waxes-polishes-clays/ Do test areas to see how well it performs, it should take most marks out but deeper scratches in the clear coat will need a da polisher with the right combination of pads and varying abrasive level compounds. |
Thanks Ian
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
+1 on the clay bar just as mentioned a good wash first, they are very gentle on the paintwork but should be used with a purpose made lubricant usually bought with the bar.
After a good quality wax should make it easier to wash off as clearly it will happen again. if the bar doesn't work, then a buff with a good compound around 3000 grit should work, im sure the detailers will add some science! |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2299 ![]() ![]() ![]() |
15Minutes to watch... 3Hrs to Copy... good clean 'fun' ![]() https://www.defender2.net/forum/topic83242.html |
mattc Member Since: 10 Apr 2019 Location: Cheshire Posts: 73 ![]() ![]() ![]() |
I had a similar issue with the back of my Defender when I got it. I washed it thoroughly, used a clay bar, then used Meguiars Ultimate Compound. That removed the deposits and the scratches. I then used a fine polish to make it even shinier. It takes some elbow grease but it's easier if you have a DA polisher you can borrow.
