Home > Maintenance & Modifications > Cleaning Recommendations Please
Alun
United Kingdom 2011 Defender 90 Puma 2.4 PU Santorini Black
Can anyone recommend a cleaning approach to removing the film that's built up on my black Defender? It has a galvanised hardtop which has "leeched" onto the paintwork shown in the photos
Thanks in advance for any help or pointers
Post #913416 21st Jul 2021 12:30pm
Mdm
a good detailer would take a lot of that out but its well engrained into the paint
would be good to machine polish the car and throw some proper wax on top.
Post #913424 21st Jul 2021 1:00pm
Griff90bowler
Wales
Red 7 👍
Post #913431 21st Jul 2021 1:28pm
Ianh
Do a smal test area first, but my recommendation would be :-
Try bilt hamber korrosol https://bilthamber.com/product/korrosol/
Give it a wash and dry , Followed by a clay bar
Then use farecla G3 regular grade paste compound. https://www.farecla.com/products/g3-regula...pound/%5B/
Use a slightly damp microfibre cloth to apply in small areas at a time and add a little spray of water as the paste drys to keep the paste working. Moving the cloth up and down and side to side then in a random circular motion to finish. Then use a standard polish over the top in the same way, then buff with a different microfibre cloth.
Clays, polish and wax here https://bilthamber.com/product-category/waxes-polishes-clays/
Do test areas to see how well it performs, it should take most marks out but deeper scratches in the clear coat will need a da polisher with the right combination of pads and varying abrasive level compounds.
Post #913456 21st Jul 2021 3:40pm
Alun
Thanks Ian
Post #915519 4th Aug 2021 8:29pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
+1 on the clay bar just as mentioned a good wash first, they are very gentle on the paintwork but should be used with a purpose made lubricant usually bought with the bar.
After a good quality wax should make it easier to wash off as clearly it will happen again.
if the bar doesn't work, then a buff with a good compound around 3000 grit should work, im sure the detailers will add some science!
Post #915583 5th Aug 2021 8:58am
Alun
Thumbs Up
Post #915620 5th Aug 2021 12:38pm
X4SKP
15Minutes to watch... 3Hrs to Copy... good clean 'fun' Thumbs Up SKIP
Post #952871 18th May 2022 12:23pm
mattc
United Kingdom 2005 Defender 90 2.5 TD HT Java Black
I had a similar issue with the back of my Defender when I got it. I washed it thoroughly, used a clay bar, then used Meguiars Ultimate Compound. That removed the deposits and the scratches. I then used a fine polish to make it even shinier. It takes some elbow grease but it's easier if you have a DA polisher you can borrow.
Post #952873 18th May 2022 12:53pm
