Home > Puma (Tdci) > Help please with fault codes and diagnosis.
astroarcadia
I have a 2007 2.4 with the MIL on. All stock, no reap or EGR delete.
I have black smoke on start up and and when under pressure. The vehicle is in limp mode with little or no turbo. I get a chugging when I start up and get going.
Fault codes shown are:
P0100 - Mass Airflow Circuit Problem.
P0234 - Intake boost pressure sensor input signals intake pressure above the maximum specified pressure by 4 psi for more than 5 seconds
P1103 - The voltage signal from the Mass Air Flow (MAF) sensor is higher than normal.
I have changed air filter, fuel filter and the MAF for genuine and also the VCV.
I have also remove the EGR and cleaned and refitted.
Any ideas on what is causing all this?
I have checked hoses for leaks also.
Post #913411 21st Jul 2021 12:08pm
Bluest
Is the turbo actuator free moving? 2007 110 TDCi Station Wagon XS
Post #913418 21st Jul 2021 12:36pm
astroarcadia
Please forgive me, how can I check this?
Post #913422 21st Jul 2021 12:58pm
Pacha
Post #913427 21st Jul 2021 1:11pm
astroarcadia
I have removed the actuator and the o ring retainer holding the arm. The arm will move but it very stiff and feels like it is almost grinding through three positions as I move it.
Post #913438 21st Jul 2021 1:44pm
astroarcadia
Have revved the engine and the aviator arm move freely when revs given.
Also I get the click click click sound when I turn off. Does this signal the EGR is working correctly?
Post #913445 21st Jul 2021 2:02pm
astroarcadia
I cleared the faults and took the vehicle for a run.
The MIL has remained off but the turbo does feel weak, its doesn't pull.
I plugged the reader back in and the only fault showing is P0234 - Intake boost pressure sensor input signals intake pressure above the maximum specified pressure by 4 psi for more than 5 seconds.
Post #913446 21st Jul 2021 2:14pm
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I remember reading the actuator should feel quite loose? Not taken mine off..... yet..
Post #915446 4th Aug 2021 12:56pm
DefenderCat37
 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi astroarcadia, I know this post was a while ago now, but I have a similar problem. Did you get to the bottom of what caused it?
Cheers.
Post #995669 8th Jun 2023 8:48pm
