Home > Puma (Tdci) > Help please with fault codes and diagnosis. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Is the turbo actuator free moving? 2007 110 TDCi Station Wagon XS
21st Jul 2021 12:36pm |
astroarcadia Member Since: 12 Jun 2020 Location: Gloucestershire Posts: 49 |
Please forgive me, how can I check this?
21st Jul 2021 12:58pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Here:-
https://www.defender2.net/forum/post853115.html#853115 Rgds. Chris |
21st Jul 2021 1:11pm |
I have removed the actuator and the o ring retainer holding the arm. The arm will move but it very stiff and feels like it is almost grinding through three positions as I move it.
21st Jul 2021 1:44pm |
Have revved the engine and the aviator arm move freely when revs given.
Also I get the click click click sound when I turn off. Does this signal the EGR is working correctly? |
21st Jul 2021 2:02pm |
I cleared the faults and took the vehicle for a run.
The MIL has remained off but the turbo does feel weak, its doesn't pull. I plugged the reader back in and the only fault showing is P0234 - Intake boost pressure sensor input signals intake pressure above the maximum specified pressure by 4 psi for more than 5 seconds. |
21st Jul 2021 2:14pm |
Moffett Member Since: 08 May 2018 Location: Sligo Posts: 69 |
I remember reading the actuator should feel quite loose? Not taken mine off..... yet..
4th Aug 2021 12:56pm |
DefenderCat37 Member Since: 24 May 2023 Location: Essex Posts: 7 |
Hi astroarcadia, I know this post was a while ago now, but I have a similar problem. Did you get to the bottom of what caused it? Cheers. |
8th Jun 2023 8:48pm |
