![]() | Home > Puma (Tdci) > Remove XS grille? |
If it's an aircon grille then the easiest way is to remove the grille surround as the grille comes with it, they are only held on with two self tappers each side and about four smaller ones along the top. Steve.
firtree clips,just push them through from the back using a credit card so not to damage them
![]() 1968 1/32 scale Britains 109 Pick up. |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Indeed - it is an a/c grille. |
Doh... didn't think of that. ![]() Thanks! ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
As MOB says- much easier taking the whole thing off ![]() Glyn ![]() ![]() |
I didn't notice the self-tappers, I was led astray by the Mantec instructions that showed the grille being removed by 6x screws.
I'll have a look when I get home and have a go. It'd be nice to get the steering guard put on eventually. |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
As above take the whole assembly off. Just did mine, 4xself tappers on the top and one each side. Flip the thing over and you can push out the plastic firtrees. 5 mins tops.
Stu |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Get it wrong it could be expensive! ![]() ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
slightly OT but in all the years i have been working on vehicles at home i have never heard the clip called a firtree clip before.
just googled it and had one of the "ah ha , of course" moments ![]() |
It's an easy job to get off. The small self tapers have oversize washers and screw into plastic inserts, the two larger screws eack side of the surround screw into speed fasteners clipped onto bent brackets - a bit of copperslip on the screw threads will help to stop them corroding onto the fasteners. While you've got the grille off slap some Waxoyl or similar onto he brackets that hold the a/c fan as they tend to rust like mad too. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
BM - I meant the credit card bit. I know its my werid sense of humour! ![]() ![]() |
Thanks guys - that worked. Grille came right off.
Good call on the copper grease, the screws on the side were melding into the support. |
FD7 Member Since: 16 Feb 2021 Location: Midland Posts: 182 ![]() ![]() |
sorry to BUMP this back up after so many years... but I'm finding it hard to remove the grill from the surround. Have tried pushing the black clips but they almost warp and don't feel like they're going to move.
In the 12 years that have since past, can anybody help advise? |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 813 ![]() ![]() ![]() |
Is there enough room to just cut the clips off from behind? New ones are cheap enough 😎
