Home > Puma (Tdci) > Glow Plug Relay Error and location?
AndyS
Hello,
My local mechanic plugged my car (2011 XS) into his error reading machine and the only fault was Glow Plug Relay so I've got a new one, easy job I thought, just plug in the new one. However, the interwebs says it should be number four in this picture...
Yet my car seems to be missing number four...
On the end of the brown wires are a couple of fuses but no relay...
That black box on the bottom is for the fog light...
There's nothing at all in the user handbook and the glow plug light on the dash does what you'd expect (light up before starting, goes out after a few second and then car starts).
Should I just forget about this? How can I identify any of those relays if they don't follow the plans on the internet? What on earth is going on, is the wiring on a defender a bit random? What relay is missing?
Thanks,
Andy.
Post #908997 22nd Jun 2021 7:02pm
Martin
Site Admin
You are missing relay #1, the pre-2011 ABS relay.
Glow relay is the grey one in position 4 Smile
The prescence of the glow lamp doesn't mean the glow relay is working, the ECU has feedback from the output of the glow relay through Fuse 38 (10A). Check this fuse as well - check it is seated properly if not blown (remove and refit) Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #909001 22nd Jun 2021 7:13pm
AndyS
Thank you very much. It's changing a relay, 'how hard can it be?' I thought. Very Happy
Post #909012 22nd Jun 2021 7:54pm
AndyS
Sorry to resurrect an old thread but it's the same issue. Back in the summer I replaced the glow plug relay because when plugged in and looking for error codes, the only one listed was glow plug relay (that wasn't the issue I was trying to fix, it turned out to be the fuel pressure thingy).
The question, does the error code need clearing to get the glow plugs/relay to work?
Truck is reluctant to start when it's cold, I suspect it's still a glow plug issue as it starts fine when the temperature is over 5°c.
Post #936572 6th Jan 2022 10:57am
hank
Don't know the answer for sure but suspect that the fault code does not need to be cleared. If the glow plug light is illuminating on the dash then the ECU is trying to go through the cycle.
I recently got my glow plugs back working - couple of things to check here https://www.defender2.net/forum/topic81190.html > 110 XS Double Cab
Post #936577 6th Jan 2022 12:16pm
AndyS
Thanks Hank, I've just replace all those fuses as the old ones weren't see-through to see if they're any good. Just need a cold morning to test it. 🤞
Post #936703 7th Jan 2022 12:22pm
