Home > Camping, Caravanning and Holidays > Fire pit recommendations
Page 1 of 3 123>
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Morning,
I'm looking for some advice/guidance/recommendations on folding fire pits. We've had various cheap ones for camping, generally with folding legs and thin steel but they don't last and tend to warp etc once they've been used a couple of times.
A bit of searching has found a couple of more robust options made typically from thicker 3mm steel but attracting a significant increase in price. I'm happy to spend a bit more on something that will last but I'm intrigued to see what other people have experienced.
My preferred options are looking like a choice between:
K2 Design 3mm mild steel (I suspect I'd get it without the "one life live it" branding)
or
Grill 'n Fire made from 3mm Corten steel (in theory with a 10yr guarantee)
The collapsible aspect of both of these and having the fire off the ground allowing us to use it without leaving a mark on the landscape/campsite are the main drivers. That rules out the front runner Braai style
So what do people think on the chances of 3mm steel holding up and not warping? Are there any options I haven't considered that you could recommend?
Thanks Keith
Post #907179 10th Jun 2021 8:20am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
My experience is that the cast iron one last, all the steel warp/rust/fall apart. Not found a collapsable cast iron one yet.
Post #907180 10th Jun 2021 8:47am
wyvern
We have one of these for the very rare occasions that we use a fire pit ...
its a fine wire mesh and holds the wood and ash off the ground with 4 legs - very cheap, very simple and folds up very small
https://www.amazon.co.uk/SUCHDECO-Portable...s9dHJ1ZQ==
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #907189 10th Jun 2021 9:52am
AJC
If you can live with out it folding, i use an old beer keg, it doesn't warp and when travelling you put the logs etc inside it.
my mate has the same idea and has a bracket that holds his to the spare wheel.
Post #907208 10th Jun 2021 11:23am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
We have one like this for when trailer space is tight. It does warp when hot but has lasted at least 7 years so far:
https://www.jmart.co.uk/products/new-engla...olding-bbq
However, our #1 firepit/BBQ/oven things is an Aquaforno II which although not foldable, is telescopic so packs away smaller than when in use:
https://aquaforno.com/
We have the stainless version which seems to be no longer available:
Post #907219 10th Jun 2021 12:00pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
Another one that doesn't fold but we went for one of these http://www.bush-pig.co.uk/home/4570893280
It works great as a BBQ then throw some logs in it to use it as a fire pit, it even has a lid to prevent any stray embers after you've gone to bed.
Post #907247 10th Jun 2021 2:22pm
Harry.O
A slight curveball to what you are after but Lidl do a good fire pit with a tripod and a grill for about £25. The legs unscrew from the main pit and the 3 legs that support the suspended grill also dismantle with everything going inside a carry bag the diameter of the bowl. It's a bit more of a faff to dismantle and doesn't have a lid that you can close down but the adjustable height of the grill is great for cooking and it takes proper sized logs whilst keeping the fire off the ground. Ours has survived 3 years of regular use with no problems Thumbs Up
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #907263 10th Jun 2021 3:31pm
Keith5
Thumbs Up
I had seen these online but never in real life. Worth a look. Thanks Keith
Post #907332 10th Jun 2021 10:26pm
Keith5
Very cool but beyond what my budget and approved scope covers. Keith
Post #907333 10th Jun 2021 10:27pm
miker
My scout unit has fire stands that consist of a ~800mm high collapsing trestle and a piece of 5 or 6mm plate for the top. Folds down nice and "flat" but every single plate looks like a Pringle Laughing
Post #907334 10th Jun 2021 11:54pm
bear100
We use the Bushpig, for a fire pit and cooking, they have a great range of accessories too from bread oven to rotisserie.
comes in a neat bag and very easy to clean with just a wipe over with a wet wipe.....still looks like new 5 years down the line! 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #907340 11th Jun 2021 6:09am
Keith5
The bushpig is looking like a good option, does it have a grid for the coals to keep the heat off the base of the unit?
Or is it worth adding as an extra item: http://www.bush-pig.co.uk/shop/4571620233/..../11305383 Keith
Post #907342 11th Jun 2021 6:15am
X4SKP
Hello Keith5
Off Brief as neither fold, but two variations on the theme, up/recycle either a Gas Bottle (good thickness Steel)
or use the inner drum from a washing machine, perfect perforated Stainless Steel. Plenty variations on these two
approaches on line (Pinterest) Thumbs Up
Good Luck SKIP
Post #907361 11th Jun 2021 8:10am
Whirly90
Definitely worth getting as an extra, the heat makes no difference to the base but it provides air flow around the coals and it cooks loads better.
Post #907411 11th Jun 2021 1:06pm
bankz5152
My current set up + a block of wood to place the pit on served me well thru france/spain/pryenees
 Instagram @defender_ventures
Empire Tuning - Agent
Post #907436 11th Jun 2021 4:26pm
Page 1 of 3 123>
