Home > Camping, Caravanning and Holidays > Fire pit recommendations |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
My experience is that the cast iron one last, all the steel warp/rust/fall apart. Not found a collapsable cast iron one yet.
10th Jun 2021 8:47am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2101 |
We have one of these for the very rare occasions that we use a fire pit ...
its a fine wire mesh and holds the wood and ash off the ground with 4 legs - very cheap, very simple and folds up very small https://www.amazon.co.uk/SUCHDECO-Portable...s9dHJ1ZQ== Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Jun 2021 9:52am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1359 |
If you can live with out it folding, i use an old beer keg, it doesn't warp and when travelling you put the logs etc inside it.
my mate has the same idea and has a bracket that holds his to the spare wheel. |
10th Jun 2021 11:23am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
We have one like this for when trailer space is tight. It does warp when hot but has lasted at least 7 years so far:
https://www.jmart.co.uk/products/new-engla...olding-bbq However, our #1 firepit/BBQ/oven things is an Aquaforno II which although not foldable, is telescopic so packs away smaller than when in use: https://aquaforno.com/ We have the stainless version which seems to be no longer available: Click image to enlarge |
10th Jun 2021 12:00pm |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 405 |
Another one that doesn't fold but we went for one of these http://www.bush-pig.co.uk/home/4570893280
It works great as a BBQ then throw some logs in it to use it as a fire pit, it even has a lid to prevent any stray embers after you've gone to bed. |
10th Jun 2021 2:22pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 712 |
A slight curveball to what you are after but Lidl do a good fire pit with a tripod and a grill for about £25. The legs unscrew from the main pit and the 3 legs that support the suspended grill also dismantle with everything going inside a carry bag the diameter of the bowl. It's a bit more of a faff to dismantle and doesn't have a lid that you can close down but the adjustable height of the grill is great for cooking and it takes proper sized logs whilst keeping the fire off the ground. Ours has survived 3 years of regular use with no problems
Click image to enlarge 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
10th Jun 2021 3:31pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
I had seen these online but never in real life. Worth a look. Thanks Keith |
10th Jun 2021 10:26pm |
Very cool but beyond what my budget and approved scope covers. Keith |
10th Jun 2021 10:27pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
My scout unit has fire stands that consist of a ~800mm high collapsing trestle and a piece of 5 or 6mm plate for the top. Folds down nice and "flat" but every single plate looks like a Pringle
10th Jun 2021 11:54pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1913 |
We use the Bushpig, for a fire pit and cooking, they have a great range of accessories too from bread oven to rotisserie.
comes in a neat bag and very easy to clean with just a wipe over with a wet wipe.....still looks like new 5 years down the line! 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
11th Jun 2021 6:09am |
The bushpig is looking like a good option, does it have a grid for the coals to keep the heat off the base of the unit? Or is it worth adding as an extra item: http://www.bush-pig.co.uk/shop/4571620233/..../11305383 Keith |
11th Jun 2021 6:15am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Keith5
Off Brief as neither fold, but two variations on the theme, up/recycle either a Gas Bottle (good thickness Steel) or use the inner drum from a washing machine, perfect perforated Stainless Steel. Plenty variations on these two approaches on line (Pinterest) Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
11th Jun 2021 8:10am |
Definitely worth getting as an extra, the heat makes no difference to the base but it provides air flow around the coals and it cooks loads better. |
11th Jun 2021 1:06pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2149 |
My current set up + a block of wood to place the pit on served me well thru france/spain/pryenees
Click image to enlarge Click image to enlarge Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
11th Jun 2021 4:26pm |
