Home > Td5 > Saving ecu map on nanocom as ".map" file
Page 1 of 3 123>
hugh_b
Hoping someone can help me with this. I am trying to save my ecu map on a nanocom one as a ".map" file but it will only let me save it as a tuning file. Does any one know how to save it as a ".map" file?
Thanks
Hugh
Post #85470 21st Aug 2011 2:53pm
Alive Tuning
It cannot be done, Hugh, as tuned nanocom files are encrypted and locked to your vehicle.
If you can read your .tun file, then you've got a backup which can be re-applied to your car as many times as you like.
If you need any further assistance, feel free to give me a call or drop me an email.
Post #85552 22nd Aug 2011 9:32am
hugh_b
Thanks Gary. I was under the impression I needed a .map file as a backup. I have the .tun file saved on my laptop.
Thanks
Hugh
Post #85556 22nd Aug 2011 10:23am
Sorry to hijack the thread...
Gary, are saying then, if i were to take a .tun file image of my ECU, this would be a complete "backup" of it, alarm settings/engine tune file/etc all in one?
would this include any modified tune file as well?
cheers
Post #85610 22nd Aug 2011 8:37pm
Alive Tuning
cheers
It would be a complete backup of the engine ECU calibration maps and software only. Configuration data such as Immobiliser code, Injector grades, Throttle type, etc are not stored within the .map or .tun files, but can be saved separetly.
Each .map or .tun file will hold one set of ECU calibration data only.
Post #85616 22nd Aug 2011 9:19pm
Cheers for that Thumbs Up
so, being dim here....I assume calibration maps to be the "tune" file... i.e. standard or go faster?
Post #85618 22nd Aug 2011 9:21pm
Alive Tuning
Correct. Thumbs Up
Post #85637 22nd Aug 2011 10:34pm
johnnyd
If i want to backup my mappings and try another stage1 map, how/what do i backup first with the nanocom evolution ?
This is a 1998 TD5 with a replacement 000120 ECU
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #245311 21st Jun 2013 10:46am
Alive Tuning
Simply read the map file from the ecu, and Nanocom will save it as a .map or .tun file onto the SD card. You can then program whatever you like onto your ecu, and when you're done, and you want to re-install your saved map, simply select to write map file, or write tuning map file back onto the ecu.
Td5 can be immensely unreliable at programming, and so don't flash the ecu any more times than you need to.
Post #245312 21st Jun 2013 10:53am
johnnyd
Many Thanks
Is there a risk of trashing the ECU then ? 2008 TDCi 2.4 XS CSW
Post #245314 21st Jun 2013 10:56am
Alive Tuning
johnnyd wrote:
Many Thanks
Very much so! Exclamation hence my advice on not flashing it any more times than you need to. Once your tuning is on there, and you're happy with it, Leave it alone.
If your ecu does die during programming, you can send it into us and we can revive it, and apply your tuning map as well.
Regards,
Gary.
Post #245319 21st Jun 2013 11:01am
johnnyd
Hi Gary
Yikes .....Now I'm scared......
Its not the original ECU as mine would have been an NNN (1998) it has been replaced at some point with a 000120, does that make it any better or worse Gary ?
Post #245321 21st Jun 2013 11:04am
Alive Tuning
Your original ECU would have had an MSB part number, possibly an MSB101170, which Land Rover could well have replaced as a recall. There is no real difference in the way the engine would run between an MSB and a NNN ecu, assuming it has the correct software programmed onto it.
Post #245329 21st Jun 2013 11:31am
johnnyd
If I try and backup the ecu map it comes up with a blank 'select folder' window.....I can't seem to do anything from that point, if I select continue, the backup starts then fails, any ideas anyone? Do I need some sort of folder structure?
Post #245437 21st Jun 2013 8:02pm
If you go to the nanocom website, you can view the evo manual on line, or right-click this link ----> and download it to your PC or download links for instructional evo videos
Post #245454 21st Jun 2013 8:58pm
Page 1 of 3 123>
