![]() | Home > Td5 > Saving ecu map on nanocom as ".map" file |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Wow the 4th SD card worked .............. 2008 TDCi 2.4 XS CSW
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
You need an old type SD card. My own evo has a 256Mb SD card that works perfectly. I tried a newer 1Gb card once, and it wouldn't handle files at all on that.
Oddly enough the first 3 I tried were old, and the one that worked and I could copy my ecu map too was a new 8gb sandisk micro SD .....I guess it's quite random......
JD 2008 TDCi 2.4 XS CSW |
I'm just reading some threads on forums, if I am allowed to post one here....http://forums.lr4x4.com/index.php?showtopic=63548
And there are a few comments about remapped tuned engines having stress issues etc, is the twisted stage 1 remap a relatively safe one? I would hate to damage my treasure .......does it need careful driving, I havn't done anything with inter coolers etc yet. JD 2008 TDCi 2.4 XS CSW |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5852 ![]() ![]() |
No it will be fine @ a stage one, and even a stage 3, if you engage brain first.
Andy |
WOW WOW WOW WOW........
Remap done successfully and WHAT a difference.............it's incredible........... Now for stage 2 and inter cooler ![]() And this really will not over stress the engine at all? I can't believe how much more acceleration it has....... WOW WOW WOW WOW.... 2008 TDCi 2.4 XS CSW |
![]() But shout it at them in German because life is also terrifying and confusing... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6162 ![]() ![]() ![]() |
Mine is an old Mk1 nanocom, so doesn't have any SD card sockets on it. It's got some internal memory (about enough for 2 ECU files) so I have to upload to & from my laptop. no big deal really. Glad the tune worked! |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Google this : calculating the nanocom checksum
You should have your answer on the .tun and .map. If you don't understand what it means, then don't mess with it. I'm not trying to say what you can do or can't do with it. So draw your own conclusions to the information. That's all I should say. The defender has migrated, leaving the owner behind. |
Richalot Member Since: 02 Nov 2013 Location: Norfolk Posts: 37 ![]() ![]() |
Hello, I have just been reading through your posts, sounds great. I want to do the same to my TD5 110 defender I have a understand what being done but have idea were to start. i could go bye one already done but thats not mei would like to learn how to rempap the ECU like you have. Can you help me get started with this ie what do i need to purchase and from were ie the interface / mapping software the remapped files etc thank you in advance |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
This is the map editing software I use.
http://www.evc.de/en/product/ols/software/default.asp |
Skye_Rover Member Since: 30 Aug 2013 Location: Skye Posts: 85 ![]() ![]() ![]() |
If you are worried, or want to do the job properly, then put some instrumentation on the engine. A minimum would be a thermocouple probe in the exhaust manifold. That way, you are keeping an eye on things if you need to use your Defender in a more extreme environment (sustained towing across Europe, trips to mountain resorts, trips to southern France/Spain, etc. etc.). Roads? Where we're going, we don't need roads. |
Now that to me is like trying to understand a womans mood swings
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
JWL- when you find out what they mean can you let us all know please
![]() ![]() CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
