Home > Wheels & Tyres > Think these may be a bit big
bodstruck
Picked up some more wheels and tyres for the 110 yesterday. BFG KM2s 33 x 12.50 x 15 on ET0 modulars. I knew they were wider than the existing ones but when compared side by side they seem like whoppers Smile
Might be a bit Carlos Fandango for me but I will put them on and see how they look and drive.
Post #904429 22nd May 2021 2:20pm
Beero
Only people of a certain age will know what Carlos Fandango means!! The rest will have to google it
Post #904486 22nd May 2021 10:25pm
I expect you will like them in the end though. Very Happy WeWillWin🇬🇧🇺🇸
Post #904490 22nd May 2021 10:55pm
JOW240725
Oooh they are big, I want to see them on! Thumbs Up James
Instagram @suffolk_rovers
Post #904502 23rd May 2021 5:57am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Get them on and let see the results, before and after if you can Thumbs Up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #904511 23rd May 2021 8:04am
camelman
I'm running 315/75/16 on the Black 110. They're equivalent to a 35/12.15
You might lose some lock as I'm running et-32 wheels, does mean they stick out and you need wider arches however...
Post #904535 23rd May 2021 11:33am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Here you go, every other vehicle here has that size fitted Smile
A significant disadvantage is the amount of muck up the side of a vehicle, and stone damage if on gravel roads.
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #904539 23rd May 2021 12:05pm
bodstruck
showing my age a little, oops Embarassed
Thanks for the pic BogMonster
Coincidentally, I was out on Salisbury Plain yesterday with someone who had this size on his 110. They fill the arches nicely and did not stick out too far but you are right, there was loads of mud spattered all up the side of his truck.
I might keep the 235s on the tdi for now and save these for the td5
Post #904673 24th May 2021 12:26pm
L110CDL
I too remember that advert Wink Clayton.
Keeper.
Post #904841 24th May 2021 10:52pm
markb110
What are the 35's like on upwards travel. Will they damage the arches?
This was my last 110 on 255 / 85's with a two inch lift
Post #904845 24th May 2021 11:21pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Brilliant advert by Panama Rolling with laughter Rolling with laughter
Post #905081 26th May 2021 12:00pm
JOW240725
I remember that advert! Embarassed James
Post #905142 26th May 2021 5:25pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
This is my 90 with about 7cm lift and 35" Simexes.
As you can see I modified the wheelarches a bit, but this really depends on the ET value off the rims. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #905248 27th May 2021 8:11am
markb110
Thumbs Up
Do love the pictures you post…. Very Happy
Post #905300 27th May 2021 1:07pm
camelman
315 75 16s from ground level.
Running et-32 50mm lift and +50mm arches
Post #905585 29th May 2021 8:55am
