![]() | Home > Wheels & Tyres > Think these may be a bit big |
Beero Member Since: 05 Jan 2021 Location: Southampton Posts: 21 ![]() ![]() |
Only people of a certain age will know what Carlos Fandango means!! The rest will have to google it
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
I expect you will like them in the end though.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Oooh they are big, I want to see them on!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Get them on and let see the results, before and after if you can
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
I'm running 315/75/16 on the Black 110. They're equivalent to a 35/12.15
You might lose some lock as I'm running et-32 wheels, does mean they stick out and you need wider arches however... ![]() |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Here you go, every other vehicle here has that size fitted
![]() A significant disadvantage is the amount of muck up the side of a vehicle, and stone damage if on gravel roads. ![]() Click image to enlarge --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 976 ![]() ![]() |
showing my age a little, oops
![]() Thanks for the pic BogMonster Coincidentally, I was out on Salisbury Plain yesterday with someone who had this size on his 110. They fill the arches nicely and did not stick out too far but you are right, there was loads of mud spattered all up the side of his truck. I might keep the 235s on the tdi for now and save these for the td5 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10958 ![]() ![]() |
I too remember that advert
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2662 ![]() ![]() ![]() |
What are the 35's like on upwards travel. Will they damage the arches?
This was my last 110 on 255 / 85's with a two inch lift ![]() Click image to enlarge |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Brilliant advert by Panama ![]() ![]() |
I remember that advert!
![]() Click image to enlarge This is my 90 with about 7cm lift and 35" Simexes. As you can see I modified the wheelarches a bit, but this really depends on the ET value off the rims. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
![]() Do love the pictures you post…. ![]() |
315 75 16s from ground level.
Running et-32 50mm lift and +50mm arches ![]() Click image to enlarge ![]() |
