Home > My New Defender (L663) > Cracked screen.
Gareth
Cracked screen.
Got a hit from a very small pepple, cracked right in my eye line. 😡 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #902013 8th May 2021 1:09pm
Sulisuli
Can it be repaired Gareth or is it a new screen requirement? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #902019 8th May 2021 2:05pm
Retroanaconda
Welcome to the club, mine is cracked too:
Be prepared for a wait - the screens are on back order from Land Rover.
Post #902029 8th May 2021 2:24pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
I was reading on a farce book site that there are numerous cases of the screen cracking from either a minor impact or for no reason at all?
Could it be that there is too much flex in the body or is it a case of substandard windscreens?
Jim
Post #902036 8th May 2021 3:28pm
Gareth
Yes seems to be prone to damage. I think mine is repairable. It’s a small crack in the outer laminate, about 10mm.
NFU paying minus £50.
Mine is definitely an impact. About 50 mph on M54, heavy rain. Car in front wandered onto centre reservation and flicked up some gravel. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #902037 8th May 2021 3:55pm
Retroanaconda
I don’t think it’s body flex as that would mean cracks from the edge with no reason, all the cracked screens I’ve seen have been from impact damage - just at a much higher incidence rate than I would consider normal.
My theory is it’s just cost/weight saving meaning thinner windscreens which are less robust. Autoglass tried to fob me off with an aftermarket screen hence the delay as now I have to wait for the proper one to be available.
Post #902040 8th May 2021 3:58pm
SN
Ouch. Got to drive from SE Manchester to Torquay (and back) with work next week, am going to be nervously not driving too close behind other vehicles... Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #902086 8th May 2021 11:36pm
Post #902089 9th May 2021 5:59am
deaston
Re: Cracked screen.
Is a pepple a really small pebble?
Post #902112 9th May 2021 7:55am
deaston
But if the proper ones keep cracking, why not try an aftermarket one? It might be better.
Post #902113 9th May 2021 7:57am
Retroanaconda
I very much doubt it.
The issue is warranty - LR won’t honour anything connected with the windscreen (an awful lot) if we were to use a non-original replacement screen.
Post #902212 9th May 2021 5:30pm
Gareth
It’s going to be repaired. No point in going through all the hassle for the sake of a small chip. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #902215 9th May 2021 5:37pm
DSL
Obviously it’s not in the can’t get repaired zone?
Post #902242 9th May 2021 7:17pm
Gareth
Where is that zone? It’s at 8’oclock in my view, in the zone that is wiped by the right hand wiper. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #902246 9th May 2021 7:28pm
DSL
ISTR it’s a line from top of screen to bottom, passing through the centre of the steering wheel, then 10cm either side. But i might be wrong
Ignore that:
https://www.optic-kleer.co.uk/articles/art...indscreen/
https://www.autoglass.co.uk/glass-repair-a...en-repair/
Post #902247 9th May 2021 7:31pm
