![]() | Home > My New Defender (L663) > Cracked screen. |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 ![]() ![]() |
Got a hit from a very small pepple, cracked right in my eye line. 😡 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Can it be repaired Gareth or is it a new screen requirement? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 842 ![]() ![]() ![]() |
I was reading on a farce book site that there are numerous cases of the screen cracking from either a minor impact or for no reason at all?
Could it be that there is too much flex in the body or is it a case of substandard windscreens? Jim |
Yes seems to be prone to damage. I think mine is repairable. It’s a small crack in the outer laminate, about 10mm.
NFU paying minus £50. Mine is definitely an impact. About 50 mph on M54, heavy rain. Car in front wandered onto centre reservation and flicked up some gravel. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 ![]() ![]() |
I don’t think it’s body flex as that would mean cracks from the edge with no reason, all the cracked screens I’ve seen have been from impact damage - just at a much higher incidence rate than I would consider normal.
My theory is it’s just cost/weight saving meaning thinner windscreens which are less robust. Autoglass tried to fob me off with an aftermarket screen hence the delay as now I have to wait for the proper one to be available. |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 ![]() |
Ouch. Got to drive from SE Manchester to Torquay (and back) with work next week, am going to be nervously not driving too close behind other vehicles... Steve N | 21MY Defender
For a possible solution:
https://www.defender2.net/forum/post898416.html#898416 |
deaston Member Since: 18 Dec 2020 Location: UK Posts: 150 ![]() ![]() |
Is a pepple a really small pebble? |
But if the proper ones keep cracking, why not try an aftermarket one? It might be better. |
I very much doubt it.
The issue is warranty - LR won’t honour anything connected with the windscreen (an awful lot) if we were to use a non-original replacement screen. |
It’s going to be repaired. No point in going through all the hassle for the sake of a small chip. 2021 Defender 110 X-Dynamic HSE D300 MHEV
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
Obviously it’s not in the can’t get repaired zone?
Where is that zone? It’s at 8’oclock in my view, in the zone that is wiped by the right hand wiper. 2021 Defender 110 X-Dynamic HSE D300 MHEV
ISTR it’s a line from top of screen to bottom, passing through the centre of the steering wheel, then 10cm either side. But i might be wrong
Ignore that: https://www.optic-kleer.co.uk/articles/art...indscreen/ https://www.autoglass.co.uk/glass-repair-a...en-repair/ |
