Home > My New Defender (L663) > Cracked screen. |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 |
Got a hit from a very small pepple, cracked right in my eye line. 😡 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
8th May 2021 1:09pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Can it be repaired Gareth or is it a new screen requirement? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
8th May 2021 2:05pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 828 |
I was reading on a farce book site that there are numerous cases of the screen cracking from either a minor impact or for no reason at all?
Could it be that there is too much flex in the body or is it a case of substandard windscreens? Jim |
8th May 2021 3:28pm |
Yes seems to be prone to damage. I think mine is repairable. It’s a small crack in the outer laminate, about 10mm.
NFU paying minus £50. Mine is definitely an impact. About 50 mph on M54, heavy rain. Car in front wandered onto centre reservation and flicked up some gravel. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
8th May 2021 3:55pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2681 |
I don’t think it’s body flex as that would mean cracks from the edge with no reason, all the cracked screens I’ve seen have been from impact damage - just at a much higher incidence rate than I would consider normal.
My theory is it’s just cost/weight saving meaning thinner windscreens which are less robust. Autoglass tried to fob me off with an aftermarket screen hence the delay as now I have to wait for the proper one to be available. |
8th May 2021 3:58pm |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 |
Ouch. Got to drive from SE Manchester to Torquay (and back) with work next week, am going to be nervously not driving too close behind other vehicles... Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
8th May 2021 11:36pm |
For a possible solution:
https://www.defender2.net/forum/post898416.html#898416 |
9th May 2021 5:59am |
deaston Member Since: 18 Dec 2020 Location: UK Posts: 150 |
Is a pepple a really small pebble? |
9th May 2021 7:55am |
But if the proper ones keep cracking, why not try an aftermarket one? It might be better. |
9th May 2021 7:57am |
I very much doubt it.
The issue is warranty - LR won’t honour anything connected with the windscreen (an awful lot) if we were to use a non-original replacement screen. |
9th May 2021 5:30pm |
It’s going to be repaired. No point in going through all the hassle for the sake of a small chip. 2021 Defender 110 X-Dynamic HSE D300 MHEV
9th May 2021 5:37pm |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
Obviously it’s not in the can’t get repaired zone?
9th May 2021 7:17pm |
Where is that zone? It’s at 8’oclock in my view, in the zone that is wiped by the right hand wiper. 2021 Defender 110 X-Dynamic HSE D300 MHEV
9th May 2021 7:28pm |
ISTR it’s a line from top of screen to bottom, passing through the centre of the steering wheel, then 10cm either side. But i might be wrong
Ignore that: https://www.optic-kleer.co.uk/articles/art...indscreen/ https://www.autoglass.co.uk/glass-repair-a...en-repair/ |
9th May 2021 7:31pm |
