Home > Technical > Replacing window hinges
Tractorman
Scotland 2011 Defender 90 Puma 2.4 HT Indus Silver
I have a 2011 Defender 90 hardtop - the window "hinges" are corroding and paint is peeling off - a common problem I understand? I could replace the hinges but I see that there is an option for a plastic cover that you clip on to the original hinge (see attached screenshot). Any views on whether or not this is a worthwhile option? Thanks.
Post #899026 19th Apr 2021 4:18pm
It's certainly a cheap option and I can see the appeal but it's only masking the problem. I'd prefer to fix it properly, to be honest. Darren
Post #899041 19th Apr 2021 6:38pm
Tractorman
Thanks Darren - that is good advice. Regards Jim
Post #899591 22nd Apr 2021 5:39pm
nitram17
Re: Replacing window hinges
The hinges bridge a big aluminium windscreen frame to large steel bulkhead and are made of ali . its a cathode/ anode corrosion problem made worse because LR don't paint the hinges before fitting to the truck so the underside isnt painted and moisture can get in under the paint at the join and moisture is required for anode corrosion...I personally would buy LR replacements and paint them all over and fit a rubber seal and refit .....keep the moisture out and you wont get to see the hinges corrode before your eyes.
Post #899654 22nd Apr 2021 11:15pm
Tractorman
Many thanks nitram 17 - advice much appreciated
Post #899939 25th Apr 2021 12:06pm
