![]() | Home > Puma (Tdci) > 2.4 white smoke on start up |
Willfindlay Member Since: 08 Mar 2021 Location: Yorkshire Posts: 24 ![]() ![]() ![]() |
When you say the vcv will sort itself out over time if you don’t do a relearn, what does this mean?
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1956 ![]() ![]() ![]() |
Fitted mine on the drive, a bit tricky with big hands but not so bad, no issues at all with it relearning itself and much smoother from the start so can only get better 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
I have done 4 of them. 1 i did the relearn the others did it over time. I have also had one duff VCV, in that once fitted vehicle wouldnt start. refitted old one and it started again.
the white smoke could just be glowplugs not 100% and its cold. i have 3 2010 defenders they all smoke on cold starts with cold ambient. (but dont have the irratic idle!) Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
