Home > My Defender > Keys
Caterham
Keys
probably a little late after 10+ years of ownership to be asking about keys but as I've never needed to use keys on the rear door I've never known the answer.
anyhow a simple question I'm sure. I presume the ignition key is also for the rear door? I know it fits the drivers door but it doesn't seem to fit the rear and neither does the fuel cap key?
Am I missing something simples here?
Post #894106 26th Mar 2021 11:56am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
I have only ever had one key for the doors and always a separate key which just fits the fuel cap.
Sounds like the rear door lock has been changed at some time, or it has seized due to lack of use.
Post #894114 26th Mar 2021 12:39pm
landy andy
Or new (second hand) door at some point which isn’t rare due to spare wheel weight.
Post #894117 26th Mar 2021 12:50pm
Caterham
hmm.
I'll try again. I've had the motor from new. so unless its had a new door / lock before I picked it up and was never given the keys? (which to be honest would not surprise me).
Post #894124 26th Mar 2021 1:04pm
discomog
Just tried the ignition key in the rear door and it works. Like you I've not tried it before. 2015 XS 90 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #894129 26th Mar 2021 1:22pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
You guys with the luxury of central locking.... you don’t know how lucky you are. And I bet you have electric windows also Big Cry Big Cry Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #894133 26th Mar 2021 1:37pm
Caterham
Thumbs Up
I've given it a thorough good going over with WD40 - see what happens the weekend.
Its absolutely solid so I'm not holding my breath. Neutral
Post #894136 26th Mar 2021 1:49pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I have Central Locking, and a separate Key for my Back Door. Looks identical to my ignition key, but ignition key doesn't work.
Probably not the original door tho
Post #904767 24th May 2021 5:26pm
balmybaldwin
The only reason I know this is my rear lock was a bit seized and the solenoid on the CL couldn't lock it. Repeated use of WD40 has freed it up so it now works on the C/L again
Post #904769 24th May 2021 5:27pm
22900013A
Central locking and electric windows came together as the "convenience pack", so yes, we have both. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #904771 24th May 2021 5:33pm
Leamreject
I’ve just fitted electric windows, got fed up of asking people on the near side to come round because my arms weren’t long enough to open the passenger window. Idea
Should I add central locking too, or just keep it simple? Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #904863 25th May 2021 5:54am
Ianh
What year is your defender ? As you will need to check your AS10 or ALM unit first as it will need to support Central Door Locking. Else it’s replacing it with a new one that does support CDL and configure it to do so.
Post #904914 25th May 2021 12:06pm
Leamreject
It’s a 2011 2.4 Puma 90 (Poverty model Whistle ) Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #904916 25th May 2021 12:12pm
Ianh
Have a look at this
https://www.defender2.net/forum/topic70599.html?highlight=cdl
Within this post is a link to a company that can add the CDL relay to the 10AS unit and provide key fobs.
https://www.technozen-electronics.co.uk/la...-services/
So It seems a mod can be done on your alarm ECU, which being a 2011 model will very likely be a green 10 AS unit. You can check by removing the drivers footwell speaker and looking upwards to the right* . If it’s green then it’s the Lucas 10AS alarm module so the mod in the post I linked to above should be applicable.
*Thats for RHD vehicles, not sure where it is for LHD defenders. Just stating for our non RHD members Very Happy
Post #904919 25th May 2021 12:21pm
Leamreject
Thumbs Up Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #905042 26th May 2021 5:25am
