Home > My Defender > Keys |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
probably a little late after 10+ years of ownership to be asking about keys but as I've never needed to use keys on the rear door I've never known the answer.
anyhow a simple question I'm sure. I presume the ignition key is also for the rear door? I know it fits the drivers door but it doesn't seem to fit the rear and neither does the fuel cap key? Am I missing something simples here? |
26th Mar 2021 11:56am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Or new (second hand) door at some point which isn’t rare due to spare wheel weight.
26th Mar 2021 12:50pm |
hmm.
I'll try again. I've had the motor from new. so unless its had a new door / lock before I picked it up and was never given the keys? (which to be honest would not surprise me). |
26th Mar 2021 1:04pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Just tried the ignition key in the rear door and it works. Like you I've not tried it before. 2015 XS 90 Defender 90XS SW
26th Mar 2021 1:22pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
You guys with the luxury of central locking.... you don’t know how lucky you are. And I bet you have electric windows also Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
26th Mar 2021 1:37pm |
I've given it a thorough good going over with WD40 - see what happens the weekend. Its absolutely solid so I'm not holding my breath. |
26th Mar 2021 1:49pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
I have Central Locking, and a separate Key for my Back Door. Looks identical to my ignition key, but ignition key doesn't work.
Probably not the original door tho |
24th May 2021 5:26pm |
The only reason I know this is my rear lock was a bit seized and the solenoid on the CL couldn't lock it. Repeated use of WD40 has freed it up so it now works on the C/L again
24th May 2021 5:27pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3149 |
Central locking and electric windows came together as the "convenience pack", so yes, we have both. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
24th May 2021 5:33pm |
I’ve just fitted electric windows, got fed up of asking people on the near side to come round because my arms weren’t long enough to open the passenger window.
Should I add central locking too, or just keep it simple? Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
25th May 2021 5:54am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2005 |
What year is your defender ? As you will need to check your AS10 or ALM unit first as it will need to support Central Door Locking. Else it’s replacing it with a new one that does support CDL and configure it to do so. |
25th May 2021 12:06pm |
It’s a 2011 2.4 Puma 90 (Poverty model ) Ride like you stole it!!
25th May 2021 12:12pm |
Have a look at this
https://www.defender2.net/forum/topic70599.html?highlight=cdl Within this post is a link to a company that can add the CDL relay to the 10AS unit and provide key fobs. https://www.technozen-electronics.co.uk/la...-services/ So It seems a mod can be done on your alarm ECU, which being a 2011 model will very likely be a green 10 AS unit. You can check by removing the drivers footwell speaker and looking upwards to the right* . If it’s green then it’s the Lucas 10AS alarm module so the mod in the post I linked to above should be applicable. *Thats for RHD vehicles, not sure where it is for LHD defenders. Just stating for our non RHD members |
25th May 2021 12:21pm |
26th May 2021 5:25am |
