Home > Puma (Tdci) > Blower speed when air con switched on but fan selector 0.
fatnold
Australia 2015 Defender 110 Puma 2.2 SW Fuji White
Has anyone had a go a varying (reducing) the speed that the blower runs at when air con is switched on? I know there needs to be reasonable airflow to stop the condenser icing up but would like to have a fan setting of about half the speed of fan setting one. Was thinking of adding a resistor prior to resistor pack as per diagram. (as a simple solution vs PMW speed controller)
Post #891051 13th Mar 2021 6:05am
