Home > Maintenance & Modifications > Help! Removing the plastic throttle / accelerator pedal
brendathedefender
United Kingdom 2002 Defender 90 2.5 TD CSW Java Black
Hi, I’m just trying to replace the plastic throttle / accelerator foot pedal. By the looks of it, it should just slide down so you can pull it off. But I’ve tried all sorts and it won’t budge at all. Am I missing anything or any suggestions would be much appreciated?!
I’ve got a new genuine LR one to replace it, but I couldn’t find any other posts on this.
Post #886936 21st Feb 2021 2:59pm
landy andy
It’s removed by bolts through the bulkhead from memory. It’s a complete unit pedal, arm, and large electronic box (potentiometer), and has wire connection on it.
Post #886967 21st Feb 2021 5:55pm
brendathedefender
Thanks landy andy, but I’m not trying to remove the whole accelerator unit, just the pedal pad: https://www.lrparts.net/sad000010pma-accel...lable.html
Do you know if this can be replaced without removing the whole unit?
Post #886980 21st Feb 2021 6:20pm
From memory, the pad has a lip all of the way around the back and needs to be 'peeled' off of the pedal. A look at the new one should tell you. Darren
Post #886990 21st Feb 2021 7:03pm
