Home > Maintenance & Modifications > Help! Removing the plastic throttle / accelerator pedal |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5568 |
It’s removed by bolts through the bulkhead from memory. It’s a complete unit pedal, arm, and large electronic box (potentiometer), and has wire connection on it.
21st Feb 2021 6:55pm |
brendathedefender Member Since: 21 Feb 2021 Location: Leamington Spa Posts: 4 |
Thanks landy andy, but I’m not trying to remove the whole accelerator unit, just the pedal pad: https://www.lrparts.net/sad000010pma-accel...lable.html
Do you know if this can be replaced without removing the whole unit? Last edited by brendathedefender on 21st Feb 2021 8:23pm. Edited 2 times in total |
21st Feb 2021 7:20pm |
From memory, the pad has a lip all of the way around the back and needs to be 'peeled' off of the pedal. A look at the new one should tell you. Darren
21st Feb 2021 8:03pm |
