Home > Td5 > Speedo transducer leaking |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
Yep. I think combination of the gear shaft and seal hardening and wear on mine.
14th Mar 2021 12:56pm |
Aaaaah that's no good Stefan, you can't put your old bits on a TV Times, you have to take shots of it on the Haynes manual or a LR publication! (Mug of tea optional)
Glad you got it sorted. Ours was definitely shaft plus seal. We've changed seal before and not solved it. Changed shaft and it's not leaked since. |
8th Jun 2021 5:33pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Called the local stealership today and they only do the oil seals in packs of 5 and o rings in packs of 10 and at stealership prices there’s no way I’m doing that.
Been trying to get through to duck worth’s but it seems impossible. Who did you contact there? Have you got an email address? Thanks |
9th Jun 2021 12:46pm |
http://minispares.com/product/classic/AAU2304.aspx
571665 o ring |
9th Jun 2021 1:39pm |
Thanks Dorset, managed to get through to duckworths in the end, apparently had computer issues today hence not being able to get through.
They’re willing to split packets and sell single items 👍 |
9th Jun 2021 4:21pm |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 |
How the did you pry the out of the transfer box? I tried some time last year and failed.
Edit: Oh, child of an unmarried couple is filtered. 2003 90 TD5 Hardtop |
9th Jun 2021 5:29pm |
A small screwdriver was sufficient for me. Someone else mentioned using a wood chisel.
10th Jun 2021 9:37am |
