Home > Td5 > Speedo transducer leaking
Page 2 of 2 <12
Matt110
Yep. I think combination of the gear shaft and seal hardening and wear on mine.
Post #891335 14th Mar 2021 12:56pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Just got round to it.
Same as yours! The shaft isn’t too bad but I think I’ll change it anway while I’m there.
Post #906931 8th Jun 2021 4:46pm
Matt110
Aaaaah that's no good Stefan, you can't put your old bits on a TV Times, you have to take shots of it on the Haynes manual or a LR publication! (Mug of tea optional) Rolling with laughter
Glad you got it sorted.
Ours was definitely shaft plus seal. We've changed seal before and not solved it. Changed shaft and it's not leaked since. Thumbs Up
Post #906933 8th Jun 2021 5:33pm
LandymanStefan
Called the local stealership today and they only do the oil seals in packs of 5 and o rings in packs of 10 and at stealership prices there’s no way I’m doing that.
Been trying to get through to duck worth’s but it seems impossible. Who did you contact there? Have you got an email address?
Thanks
Post #907050 9th Jun 2021 12:46pm
dorsetsmith
Post #907053 9th Jun 2021 1:39pm
LandymanStefan
Thanks Dorset, managed to get through to duckworths in the end, apparently had computer issues today hence not being able to get through.
They’re willing to split packets and sell single items 👍
Post #907066 9th Jun 2021 4:21pm
Mini Landie
United Kingdom 2003 Defender 90 Td5 HT Belize Green
How the Censored did you pry the Censored Censored out of the transfer box? I tried some time last year and failed.
Edit: Oh, child of an unmarried couple is filtered. Sad 2003 90 TD5 Hardtop
Post #907081 9th Jun 2021 5:29pm
LandymanStefan
A small screwdriver was sufficient for me. Someone else mentioned using a wood chisel.
Post #907184 10th Jun 2021 9:37am
Page 2 of 2 <12
