Home > Td5 > brakes and front wheel bearings |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5698 |
I would certainly be swapping towards the old fashioned bearing setup. Far better.
18th Feb 2021 5:09pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Brake pipes are metric.
18th Feb 2021 7:09pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Brake pipe unions for the calipers, master cylinder and rear axle t-piece (if no ABS) are all M10x1. Bleed nipples are the same
Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th Feb 2021 8:30pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
I've put several replacement bearings on mine and never had any issue just putting timken bearings on with the original spacers. Seen several people muse that the different spacers are more to take up tolerance in the stub axle than the bearing races!
18th Feb 2021 10:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
The stub axle won't affect the spacer but the hub probably would.
18th Feb 2021 10:27pm |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 |
Just rebuilt the swivel hubs and replaced bearing went to the old school double nut and much happier discs were ok to change replaced callipers as well factor in for new calliper bolts as they are bihex and easily rounded off especially if they have been on there a long time
18th Feb 2021 10:55pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 933 |
Me too! Far quicker and never had an issue, though I do keep a couple spare sets in the truck just in case 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
19th Feb 2021 2:59pm |
When you fit everything new it is not a problem with the new style. I went for the old style as you can adjust them when the bearings get worn a little. Roel
19th Feb 2021 5:39pm |
