Home > Td5 > brakes and front wheel bearings
cherob1boats
Hi landies, Now that horrible cold stuff has gone i need to do some work on my 2005 Td5 90. Firstly, are the brake pipe unions and bleed nipples metric or unf? Secondly, bearing in mind that my landy doesn't work to hard (bout 8 miles a day to take the dog out) is it feasable or theoretically correct to fit taper front wheel bearing kits instead of having to muck about with shims to fit the standard bearings? All replies gratefully received as ever. Thanks
Post #886353 18th Feb 2021 4:50pm
landy andy
I would certainly be swapping towards the old fashioned bearing setup. Far better.
Post #886358 18th Feb 2021 5:09pm
htb2
Wales
Brake pipes are metric.
Post #886380 18th Feb 2021 7:09pm
rallysteve
Brake pipe unions for the calipers, master cylinder and rear axle t-piece (if no ABS) are all M10x1. Bleed nipples are the same
Post #886399 18th Feb 2021 8:30pm
miker
I've put several replacement bearings on mine and never had any issue just putting timken bearings on with the original spacers. Seen several people muse that the different spacers are more to take up tolerance in the stub axle than the bearing races!
Post #886410 18th Feb 2021 10:11pm
The stub axle won't affect the spacer but the hub probably would.
Post #886413 18th Feb 2021 10:27pm
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Just rebuilt the swivel hubs and replaced bearing went to the old school double nut and much happier discs were ok to change replaced callipers as well factor in for new calliper bolts as they are bihex and easily rounded off especially if they have been on there a long time
Post #886416 18th Feb 2021 10:55pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Me too! Far quicker and never had an issue, though I do keep a couple spare sets in the truck just in case Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #886525 19th Feb 2021 2:59pm
roel
When you fit everything new it is not a problem with the new style. I went for the old style as you can adjust them when the bearings get worn a little. Roel
2003 90 Td5 (2009-now)
Post #886571 19th Feb 2021 5:39pm
