Home > Puma (Tdci) > Replace cigarette socket with USB
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Had the centre console out to hardwire a dash cam today.
Whilst I was at Halfords getting supplies, I spotted this USB port thing:
https://www.halfords.com/tools/fuses-elect...gJit_D_BwE
The first review was someone with a defender rating it, so I bought one.
I must have spent 30 mins wrestling the cigarette lighter out, for the Halfords one not to fit through the hole Big Cry and the prongs are laid out differently (so would have to replace the plug).
Has anyone used the Blue Sea ports? Do they fit through the hole?
https://www.mobilecentre.co.uk/blue-sea-10...put-da4679
Stu 2011 CSW XS 90
Post #885487 14th Feb 2021 4:14pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Stu,
I've got the Bluesea one fitted, I recall needing to gently enlarge the hole in the dash with a file when I fitted it Keith
Post #885489 14th Feb 2021 4:16pm
williamthedog
I fitted the bluesea usb, apart from the wrestling to get the cigarette lighter out it was fine, no hassle at all . I just made up a tail to fit the original connector. Thumbs Up
Post #885494 14th Feb 2021 4:38pm
hank
These work well from Ian at IRB developments. USB-A and USB-C sockets
 > 110 XS Double Cab
Post #885496 14th Feb 2021 4:39pm
BS for me too but a 12v socket. But a little enlargement if needed as suggested a round file or I used my Dremel with a little sanding drum on it. That’ll do the trick.
If you don’t want to modify the standard socket just add a mini connection loom in.
I think if I recall it’s only 5.3mm standard spade terminals. Just made sure the cable dia is equal to or slightly larger than the standard. WeWillWin🇬🇧🇺🇸
Post #885512 14th Feb 2021 5:33pm
SJM2018
Cheers for the responses Thumbs Up
That IRB one looks spot on. Hard to find any that have USB-c and charge at 3.6amp. 2011 CSW XS 90
Post #885544 14th Feb 2021 7:43pm
Oldowner
I have had to turn down the blue sea USB sockets on my myford lathe to get them to fit the three Pumas I have fitted them in to - they need a couple of mm taking off the outer rim to get them to sit properly in the recessed hole in the dash.
Post #885798 16th Feb 2021 3:06am
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I recently bought the MUD UK USB charger socket that goes in the dash as a Land Rover switch. It has two wires, a RED one and a BLACK one. I presume I have to connect it to the back of the lighter socket that has three wires RED, BLACK and PURPLE. Does RED go to RED and BLACK to BLACK?
Clueless as usual.
Post #886941 21st Feb 2021 4:37pm
Yes, the purple/green will be illumination. Darren
Post #886943 21st Feb 2021 4:40pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Don’t want to contradict, but I think the red with yellow trace is illumination. Purple wth green is ignition switched power. Sorry if I’m wrong. Have you got a multi meter to check ?
Ashbyandy
Post #886944 21st Feb 2021 4:50pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
Connect the small red wire on the Mud socket to the red/yellow wire to illuminate the USB when the lights are on
Need to cut the small red wire where it joins the large Red wire on the USB, otherwise it will be illuminated the whole time
Post #886983 21st Feb 2021 7:35pm
Ashbyandy
Ah, you're right! I should have engaged brain before keyboard. My mistake, sorry Embarassed Darren
Post #886992 21st Feb 2021 8:06pm
Ashbyandy
No problems LRA, thanks for reply, 👍
Ashbyandy
Post #887007 21st Feb 2021 8:39pm
CharlieDonuts
So like this
BLACK to BLACK
RED to PURPLE
Small RED to RED/YELLOW
Post #887155 22nd Feb 2021 8:05pm
Ashbyandy
Yep, 👍
Ashbyandy
Post #887158 22nd Feb 2021 8:44pm
