Home > Technical > 2011 PUMA REVERSE LIGHT SCHEME (Sorted)
LR90XS2011
Just picked up the caravan from having a new rear panel that included LED lights, according to the repairers they had to fit a seargent VLM4 converter to the caravan.
All the lights worked when coupled except the reverse, unplugged the caravan and the defenders reverse light was not working,
I'm unsure if it was working before I connected the caravan so I have a bit of fault finding to do. especially as I have an MOT at the end of the week already booked in
Couple of questions before I break out the multi-meter
1/ which fuse is it?
2/ is the fitting permanent live with ignition on
3/ is the negative switched to earth by the gearbox switch
3/ has anyone got a schematic for the reverse light circuit
thanks in advance DEFENDER 90 TDCI XS,
Post #885272 13th Feb 2021 2:53pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Almost 100% guarantee it’ll be the switch on the top left of the gearbox. Short 22mm spanner required. Or remove the tunnel. Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #885275 13th Feb 2021 2:58pm
landy andy
Reverse light isn’t part of MOT Thumbs Up
Post #885293 13th Feb 2021 3:50pm
LR90XS2011
sorted thanks fuse had blown
re hitched the caravan without the engine running , switched it on and worked without fuse blowing again
so watch this space DEFENDER 90 TDCI XS,
Post #885300 13th Feb 2021 4:14pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Well they fail if it doesn’t work:
Post #885314 13th Feb 2021 5:14pm
landy andy
I’m sure it never used to be part of the test.
Post #885325 13th Feb 2021 5:51pm
90 Dreamer
Believe it changed in recent years
Post #885328 13th Feb 2021 5:55pm
landy andy
Thumbs Up Thumbs Up
Thanks.
Post #885336 13th Feb 2021 6:21pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Reverse light is mandatory and part of MOT on post 2009 vehicles. Richard
Either a 90, 110 or 130.
Discovery 5
Post #885394 14th Feb 2021 6:41am
landy andy
Rule change end of May 2018 to include them and the stupid DLRs Thumbs Up Thumbs Up
Thought it must have been a fairly recent thing.
Post #885425 14th Feb 2021 9:10am
Notwithstanding that rule change, hasn't it been the case for a long time that anything that's fitted needs to work properly, even if there's no legal requirement for it to be fitted in the first place? Darren
Post #885428 14th Feb 2021 9:23am
No, that is the case for some things but not all.
Post #885429 14th Feb 2021 9:25am
