Home > Technical > 2011 PUMA REVERSE LIGHT SCHEME (Sorted) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
Just picked up the caravan from having a new rear panel that included LED lights, according to the repairers they had to fit a seargent VLM4 converter to the caravan.
All the lights worked when coupled except the reverse, unplugged the caravan and the defenders reverse light was not working, I'm unsure if it was working before I connected the caravan so I have a bit of fault finding to do. especially as I have an MOT at the end of the week already booked in Couple of questions before I break out the multi-meter 1/ which fuse is it? 2/ is the fitting permanent live with ignition on 3/ is the negative switched to earth by the gearbox switch 3/ has anyone got a schematic for the reverse light circuit thanks in advance DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 13th Feb 2021 4:14pm. Edited 1 time in total |
13th Feb 2021 2:53pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Almost 100% guarantee it’ll be the switch on the top left of the gearbox. Short 22mm spanner required. Or remove the tunnel. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
13th Feb 2021 2:58pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5790 |
Reverse light isn’t part of MOT
13th Feb 2021 3:50pm |
sorted thanks fuse had blown
re hitched the caravan without the engine running , switched it on and worked without fuse blowing again so watch this space DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
13th Feb 2021 4:14pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 322 |
Well they fail if it doesn’t work: Click image to enlarge |
13th Feb 2021 5:14pm |
I’m sure it never used to be part of the test.
13th Feb 2021 5:51pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2178 |
Believe it changed in recent years
13th Feb 2021 5:55pm |
Thanks. |
13th Feb 2021 6:21pm |
Rule change end of May 2018 to include them and the stupid DLRs
Thought it must have been a fairly recent thing. |
14th Feb 2021 9:10am |
Notwithstanding that rule change, hasn't it been the case for a long time that anything that's fitted needs to work properly, even if there's no legal requirement for it to be fitted in the first place? Darren
14th Feb 2021 9:23am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17544 |
No, that is the case for some things but not all.
14th Feb 2021 9:25am |
