Home > Puma (Tdci) > Loss of drive... Output shaft gone (i think)
Page 1 of 3 123>
conora
Hi Guys,
looking for some help if possible please...
i have a 2014 2.2 puma which is on 60k miles.
When driving home from work today i noticed the gear box made a clucking noice a couple of seconds after changing chear every once in a while. Then literally when i pulled into my road i lost all drive. i could put it into gear but when i tried to pull away it just sounded like a load of nails spinning round pretty much and nothing happened. Luckily as i was on my road, with some help i managed to push it home...
After doing some research on the forum it appears it could be the output shaft, does this sound correct? If so does anyone know how much this will roughly cost to replace?
I will call a few Defender specilists on Monday but just wanted to prepare myself.
Not brilliant timing as we're moving in a couple of weeks but one of those things aha!
Sorry im a bit of a novice and not technical when i comes to cars!
Any help would be much a appreciated.
thanks!
Post #883457 5th Feb 2021 7:32pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Presumably you have checked the transfer box is properly engaged?
Post #883460 5th Feb 2021 7:38pm
conora
yeah i check the transfer box, put it into high and low but nothing changed.
Post #883461 5th Feb 2021 7:50pm
conora
Post #883462 5th Feb 2021 7:50pm
ickle
And diff lock to rule out a diff/drive shaft / flange?
Keith
Post #883463 5th Feb 2021 8:08pm
landy andy
Where in Hertfordshire are you?
Post #883465 5th Feb 2021 8:37pm
LR90XS2011
shouldnt cost too much, but upgrade to Ashcroft or LOF if you are keeping it DEFENDER 90 TDCI XS,
Post #883466 5th Feb 2021 8:37pm
conora
based in Bushey mate!
Post #883470 5th Feb 2021 8:57pm
Pickles
Yes, definitely output shaft. Happened to us several years ago.
Was driving along, then heard a sort of click/clunk, then shortly after lost all drive.
Only issue you won't have is that it happened in Aussie in 35C+ heat, & it took around 4 hours with us sitting on the side of the road, very hot, waiting for a tilt tray!
Pickles.
Post #883478 5th Feb 2021 9:35pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Certainly sounds like an output shaft failure as this is what happened to mine but make sure the hi-lo lever hasn’t slipped into neutral 1st.
Post #883479 5th Feb 2021 9:38pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Well providing it isn't a drive flange (does it move in difflock?) then yes sounds like the output shaft.
Then if it is then LOF are the people to sort you out
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #883480 5th Feb 2021 9:40pm
Killer90
Site Sponsor
Defiantly sounds to be the output shaft mate Big Cry
Id reccomend the Ashcroft upgraded shaft kit there awesome Thumbs Up
We aren't to far from you just down the a10 from the M25 enfield turn off - do have recovery aswell if you don't have RAC or AA
Give me a shout ill try squeeze you in somewhere in the next week if I can in-between jobs Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #883482 5th Feb 2021 9:46pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Sounds very familiar.
I’d also recommend an Ashcroft upgraded shaft kit as the way to go Thumbs Up
Post #883573 6th Feb 2021 1:45pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Although so far I've been lucky with mine, I do wonder, if misalignment is the reason for these failures, whether the LOF one piece shaft is likely to move the premature failure to a bearing instead.
Post #883578 6th Feb 2021 2:15pm
jmw
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Mine went at around 40k miles. Fixed under used car warranty but I think it was around 4 hours labour. The Ashcroft part is around £350, think OEM was about £150. Whoever does it make sure they have experience as an O ring seal on mine leaked afterwards. That was another 4 hours to fix. I think the problem was thought to occur due to it being a dry coupling, hence the Ashcroft solution?
Ask to keep the parts that come off - the transfer shaft makes a good doorstop and the coupling a tea light holder! On mine you could clearly see where the teeth had worn/shredded.
Good luck.
Post #883590 6th Feb 2021 3:12pm
Page 1 of 3 123>
