Home > Puma (Tdci) > Loss of drive... Output shaft gone (i think)
Page 3 of 3 <123
nitram17
Thanks for the well thought out replies... iits a conundrum! trust land rover! I suppose since i doubt there is anybody one here that has replaced a failed shaft with a lof shaft and done 60 thousand miles yet i guess i will go with the ashcroft solution.ps just a thought ....has anybody thought it could be a combination of no lubrication overheating and differences in the quality of each input shaft manufacture.....it is unusual that they appear to wear at the same point on the shaft and the female housing splines don't appear to be affected. Could it really be down to lr quality control on shaft manufacture?
Post #883850 7th Feb 2021 7:56pm
Dinnu
I concur with what Blackwolf said above.
The fact that some shafts managed to jump off the snap ring that should hold the male with the female splines fully engaged suggest to me that quite some movement is occurring within the coupling. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #883851 7th Feb 2021 7:56pm
nitram17
Isnt that just a chicken and egg conundrum?
Post #883852 7th Feb 2021 8:13pm
jst
Have you tried diff lock as above? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #883867 7th Feb 2021 10:02pm
DSC-off
nitram17 wrote:
...has anybody thought it could be... differences in the quality of each input shaft manufacture.....it is unusual that they appear to wear at the same point on the shaft and the female housing splines don't appear to be affected. Could it really be down to lr quality control on shaft manufacture?
It has been established from the forum survey that some vehicles show a repeated pattern of failure at the same or similar milage. Sometimes 3 or 4 shafts have all failed in the same vehicle, all between (say) 20,000 and 25,000 miles, over an 8 year period.
This suggests that shafts are of a consistent quality for material, machining and heat treatment.
Other vehicles have shown a repeated failure at 30,000 miles or 40,000 miles.
This would lead me to believe there is something else peculiar to the vehicle that is causing the failure, not a random variation in the 'quality' of the shaft itself.
Post #883874 7th Feb 2021 10:28pm
Indeed, I suspect that it is the quality of machining and the tolerances on the extension housing.
Post #883877 7th Feb 2021 10:59pm
Page 3 of 3 <123
