![]() | Home > Puma (Tdci) > Loss of drive... Output shaft gone (i think) |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
Presumably you have checked the transfer box is properly engaged?
conora Member Since: 19 Jan 2018 Location: hertfordshire Posts: 25 ![]() ![]() |
yeah i check the transfer box, put it into high and low but nothing changed.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1818 ![]() ![]() ![]() |
And diff lock to rule out a diff/drive shaft / flange?
Keith |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Where in Hertfordshire are you?
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3652 ![]() ![]() ![]() |
shouldnt cost too much, but upgrade to Ashcroft or LOF if you are keeping it DEFENDER 90 TDCI XS,
based in Bushey mate!
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
Yes, definitely output shaft. Happened to us several years ago.
Was driving along, then heard a sort of click/clunk, then shortly after lost all drive. Only issue you won't have is that it happened in Aussie in 35C+ heat, & it took around 4 hours with us sitting on the side of the road, very hot, waiting for a tilt tray! Pickles. |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Certainly sounds like an output shaft failure as this is what happened to mine but make sure the hi-lo lever hasn’t slipped into neutral 1st.
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
Well providing it isn't a drive flange (does it move in difflock?) then yes sounds like the output shaft.
Then if it is then LOF are the people to sort you out ![]() Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Defiantly sounds to be the output shaft mate
![]() Id reccomend the Ashcroft upgraded shaft kit there awesome ![]() We aren't to far from you just down the a10 from the M25 enfield turn off - do have recovery aswell if you don't have RAC or AA Give me a shout ill try squeeze you in somewhere in the next week if I can in-between jobs ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 ![]() ![]() ![]() |
Sounds very familiar.
I’d also recommend an Ashcroft upgraded shaft kit as the way to go ![]() |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Although so far I've been lucky with mine, I do wonder, if misalignment is the reason for these failures, whether the LOF one piece shaft is likely to move the premature failure to a bearing instead.
jmw Member Since: 03 Aug 2019 Location: Brighton Posts: 4 ![]() ![]() ![]() |
Mine went at around 40k miles. Fixed under used car warranty but I think it was around 4 hours labour. The Ashcroft part is around £350, think OEM was about £150. Whoever does it make sure they have experience as an O ring seal on mine leaked afterwards. That was another 4 hours to fix. I think the problem was thought to occur due to it being a dry coupling, hence the Ashcroft solution?
Ask to keep the parts that come off - the transfer shaft makes a good doorstop and the coupling a tea light holder! On mine you could clearly see where the teeth had worn/shredded. Good luck. |
