Home > Puma (Tdci) > Loss of drive... Output shaft gone (i think) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3424 |
I concur with what Blackwolf said above.
The fact that some shafts managed to jump off the snap ring that should hold the male with the female splines fully engaged suggest to me that quite some movement is occurring within the coupling. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
7th Feb 2021 7:56pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Isnt that just a chicken and egg conundrum?
7th Feb 2021 8:13pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8051 |
Have you tried diff lock as above? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2021 10:02pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1428 |
It has been established from the forum survey that some vehicles show a repeated pattern of failure at the same or similar milage. Sometimes 3 or 4 shafts have all failed in the same vehicle, all between (say) 20,000 and 25,000 miles, over an 8 year period. This suggests that shafts are of a consistent quality for material, machining and heat treatment. Other vehicles have shown a repeated failure at 30,000 miles or 40,000 miles. This would lead me to believe there is something else peculiar to the vehicle that is causing the failure, not a random variation in the 'quality' of the shaft itself. |
7th Feb 2021 10:28pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17444 |
Indeed, I suspect that it is the quality of machining and the tolerances on the extension housing.
7th Feb 2021 10:59pm |
