Home > Technical > Castor Corrected Swivel Ball for the Puma
Dukes79
Switzerland 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hi to all!
I would like to know if someone fitted the Castor Correction Swivel Ball Kit from Britpart to the Puma.
Part number is DA3203 and the Swivel Ball in the Kit is the FRC7065 (new part number indicated on LR Workshop manual is FTC5366). The FTC5366 seems that can be fitted to all Defender from 1987 to 2016. So, it looks like that if I would like to fit the Castor Correction Swivel Ball Kit to my Puma with ABS I have to order separately only the Swivel pins ant the bearings. Is this correct? Can someone confirm it? Many thanks!!!
Post #882989 3rd Feb 2021 6:46pm
jst
And gaskets and seals to order. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #883043 3rd Feb 2021 11:05pm
Dukes79
Hi JST,
many thanks for your replay! Did you fit one of these or do you know if someone fitted it?
I have contacted also Britpart and Paddock spare but they are not able to confirm me that the Swivel Ball are the same as these of the Puma. Shocked
Post #883120 4th Feb 2021 10:37am
jst
I havent fitted them but as I understan it the swivel ball is the same all through less change to bearing config. But if you get bearing to suit King pi s then shouldn't be an issue Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #883238 4th Feb 2021 8:39pm
