![]() | Home > Technical > Castor Corrected Swivel Ball for the Puma |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8220 ![]() ![]() ![]() |
And gaskets and seals to order. Cheers
Dukes79 Member Since: 12 Nov 2017 Location: Lugano Posts: 3 ![]() ![]() ![]() |
Hi JST,
many thanks for your replay! Did you fit one of these or do you know if someone fitted it? I have contacted also Britpart and Paddock spare but they are not able to confirm me that the Swivel Ball are the same as these of the Puma. ![]() |
I havent fitted them but as I understan it the swivel ball is the same all through less change to bearing config. But if you get bearing to suit King pi s then shouldn't be an issue Cheers
