Home > Technical > Castor Corrected Swivel Ball for the Puma |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8007 |
And gaskets and seals to order. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Feb 2021 11:05pm |
Dukes79 Member Since: 12 Nov 2017 Location: Lugano Posts: 3 |
Hi JST,
many thanks for your replay! Did you fit one of these or do you know if someone fitted it? I have contacted also Britpart and Paddock spare but they are not able to confirm me that the Swivel Ball are the same as these of the Puma. |
4th Feb 2021 10:37am |
I havent fitted them but as I understan it the swivel ball is the same all through less change to bearing config. But if you get bearing to suit King pi s then shouldn't be an issue Cheers
4th Feb 2021 8:39pm |
