Home > Technical > Vent behind central dash panel
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Hi All,
Was doing some work on my Puma Defender and had to remove the central dash panel and noticed the air vent duct on the left had been cut/hacked about? Assuming this isnt factory, anybody come across this before or know why someone might have done this?!
https://www.dropbox.com/s/ncf7rdqfthumazn/...8.jpg?dl=0
Post #882331 1st Feb 2021 12:36pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I believe some double DIN fascia installs require cutting the vents. Can't think of any other reason.
Post #882349 1st Feb 2021 2:38pm
Definitely not factory, and it is hard to understand why that would be necessary. It is not in the position where a double-din fascia would need a cut, and I am struggling to think of any reason for doing that. Very strange.
That duct is a tricky one to replace, too, since it is so embedded in the dash.
Post #882388 1st Feb 2021 5:17pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Either that or somebody has done the wiper wheel boxes and Tori to put a piece back. They just slot into each other and all start from a centre manifold type affair.
Any pictures of what you have? 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #882401 1st Feb 2021 6:08pm
TamarBlue11
Thanks guys, is abit of a weird one! And Roy there is a link to the photo here - https://www.dropbox.com/s/ncf7rdqfthumazn/...8.jpg?dl=0
Post #882538 2nd Feb 2021 8:50am
Roy5695
There’s absolutely no reason for that part of the ducting to ever be cut 🤔 unless someone has had something wedged where the vent usually goes 🤷‍♂️ 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #882644 2nd Feb 2021 2:41pm
