![]() | Home > Technical > Vent behind central dash panel |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 ![]() ![]() ![]() |
Hi All,
Was doing some work on my Puma Defender and had to remove the central dash panel and noticed the air vent duct on the left had been cut/hacked about? Assuming this isnt factory, anybody come across this before or know why someone might have done this?! https://www.dropbox.com/s/ncf7rdqfthumazn/...8.jpg?dl=0 |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 ![]() ![]() ![]() |
I believe some double DIN fascia installs require cutting the vents. Can't think of any other reason.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Either that or somebody has done the wiper wheel boxes and Tori to put a piece back. They just slot into each other and all start from a centre manifold type affair.
Any pictures of what you have? 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Thanks guys, is abit of a weird one! And Roy there is a link to the photo here - https://www.dropbox.com/s/ncf7rdqfthumazn/...8.jpg?dl=0
There’s absolutely no reason for that part of the ducting to ever be cut 🤔 unless someone has had something wedged where the vent usually goes 🤷♂️ 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
