Home > Modifications & Maintenance (L663) > Tuning/remap d200 to d300
Page 7 of 7 <1234567
lightning
If the "genuine" remap is a LR software then l can't see how LR could refuse a warranty claim.
After all, the engine is supplied with that software in the Range Rover. Personally l am happy with my D250 and never use all the performance even when towing the caravan.
But l can fully understand people wanting theirs remapped. There's no real downside and you get an extra 50-100bhp with more torque.
Post #1052276 20th Nov 2024 9:16am
nebc100
Luxembourg
Trust me... if they notice that ANYTHING has been changed with the motor, then they will refuse warranty cover!!
It doesn't matter if you have used the Genuine remap or if you have used a aftermarket remap!!
I know this because I have a D5 that had the DETUNED version of the TDV6 (150KW rather than 180KW).
This is due to taxation. The engines are identical... it is just the tuning that is different.
I asked my dealer if they could map it with the 180KW, and they said that "could" do it, but that it would invalidate the warranty.
I then asked Alive Tuning, and they told me that they could also do it, but that each time the map is applied, there is a "counter" that increases... so the dealer can "see" if it has been modified.
They also said that if it is "mapped" (even with the OEM files), that the vehicle RISKS losing warranty not only on the engine, but on the whole drive train (transmission, diffs etc) because LR will say that you are putting more power in to the components than JLR designed when then manufactured the vehicle.
We all know that the engines are internally identical, but they don't admit that.
So... I would think VERY carefully before mapping the engine while the vehicle is still under warranty because JLR will use any excuse they can to not pay out if they can!!
Post #1052278 20th Nov 2024 9:36am
lightning
Changing a D250 to 350 takes two seconds off the 0-60mph time. Down from 8 to 6.1
So it's definitely worthwhile if you want more performance, (and your Defender is out of warranty) The engine/transmission etc should be fine as it's available with 350bhp in some versions.
Post #1052614 23rd Nov 2024 12:22pm
ruben
Spain
although your brakes will still be different…. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1052616 23rd Nov 2024 12:52pm
ruben
Spain
And who knows if your emissions levels will remain the same in the event of a future MOT? Defender 110 SE I6 D250 23MY
Post #1052617 23rd Nov 2024 12:52pm
Modder
Belgium
Did the remap from D200 tot D300, and makes a very big differance for me. A D200 is not slow, but my 90 is now really a fun car to drive also on road, overtakes and short sprints are awesome.
Yes there will be a risk attached to it if you run in to issues, but so far i would not have it any other way
Post #1053426 30th Nov 2024 10:45am
Ub_r
Belgium 2007 Defender 90 Puma 2.4 HT Indus Silver
hi, i see there are some who are from belgium. could you tell me where you did the reprogramming? because everywhere i go i am told that for versions after 2021, it is still not possible… i need it because my egr valve is starting to act up….
Post #1054577 13th Dec 2024 11:55am
snowtiger
Germany
There are definitely more differences even in the engine. The D200 has for sure different pistons than a D350. Composition may be different, as more power needs to handle more heat. And as manufacturers try to save money wherever they can, they will equip a D200 with the cheapest possible piston composition.
Regarding the spare parts, there is just the D350 piston available, as storage costs may exceed material costs, when they need to handle different pistons for different engines. That's why a lot of ppl think, engines are identical, because there is just one spare part number for pistons, rods, etc...
Post #1054617 13th Dec 2024 7:32pm
Modder
Belgium
Check DutchdefenderX on Instagram, he works with Hunter Prestige to do the upgrades in the BeNeLux
Post #1054889 16th Dec 2024 9:47pm
Modder
Belgium
Post #1054890 16th Dec 2024 9:47pm
Ub_r
ah ok, thanks! I'll have a look. Do you know if it also deactivates the EGR valve?
Post #1054913 17th Dec 2024 12:39am
DutchdefenderX
Netherlands
Hi, yes i can remap d200 -> d300 and my25 to d350
Also for the p300e -> p400E
I do this as a partner from Hunters Prestige. For benelux region. Takes between 1 and 2 hours for a propper remap with original hardware (doip) and landrover software and extra safery precautions with the battery (no brick risk)
I will not do anything with the EGR valve.
For inquiries, dm me on my instagram account.
Dutchdefenderx
This is my defender
Post #1055638 25th Dec 2024 3:53pm
