![]() | Home > Modifications & Maintenance (L663) > Tuning/remap d200 to d300 |
mausau Member Since: 15 Apr 2022 Location: Vercelli Posts: 3 ![]() ![]() |
Any new update?
irma Member Since: 06 Jan 2023 Location: Europe Posts: 7 ![]() |
Anybody done this upgrade ?
Cedric74 Member Since: 24 Aug 2021 Location: LIEGE Posts: 46 ![]() ![]() |
LR retrofit flash with oem soft, but if you need update of you’re soft…it’s gone !
vastine Member Since: 30 Mar 2023 Location: Taiwan Posts: 1 ![]() ![]() |
Seem good to go under warranty
https://bluesparkautomotive.com/land-rover...-pro-boost |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Had a look at the bluespark packs there. I’ve had two in the past - both worked ok, but caused limp mode when turned up too high.
I’m confused at the D300 box offering 364bhp. I thought the engines were identical, just detuned. Is this not the case? |
hotwheels Member Since: 30 Jan 2021 Location: South Posts: 20 ![]() ![]() |
May have some news soon
Just had the d300 map enabled by Chris at royles prestige and performance and what a difference it makes!!!! Lovely guy, genuinely knows his stuff, highly recommend!!!
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
So what happens when there is a software update or it goes into LR for servicing. Does the Map get wiped? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
It’s your choice to have a software update and you can ask for it not to be updated however it should not change the map unless the service engineer specifically chooses to alter it which is unlikely I had activations done before and service did not make any difference
ed11oad Member Since: 27 Jul 2024 Location: london Posts: 1 ![]() ![]() |
hi guys im a new member on here.
after buying a new urban 110 D300 back in april thinking it was the most powerfull diesel defender avaiable i have since found out that they make a D350. no one seems to offer a power upgrade (remap) for the D300. i dont really want a tunning module because they just dont deliver the stated power output. any information or advice greatly appreciated |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 664 ![]() ![]() |
It’s very rare for them to routinely change fuel mapping files for sold vehicles, as they’d have to go to the expense and effort of retrospectively test the changes against previous versions of engine parts/ancillaries. So, typically the only risk you have of this happening is if you had to have some engine/ecu work done. In the scenario that it did get wiped, you go back to who originally did the map file replacement and pay a labour charge to put the map file back in there. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3010 ![]() ![]() |
Do you find the D300 underpowered? |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 232 ![]() ![]() |
D300 is plenty. However it depends on your expectation and what you were driving before the defender.
The engine is a powerhouse, no matter the power! Torque is limited by the gearbox to 700nm, 675nm the d300. You will not notice the difference. You will notice the difference standstill acceleration and acceleration over 100 miles per hour. My d250 is now d300 and is adequate to all the situations. 50 horses more they are always welcome ![]() |
My D250 has plenty of reserve, even when towing the caravan.
However, l would happily upgrade the software to 300bhp if it didn't invalidate the warranty. But sadly it would. As the same engine and transmission is supplied in some versions at 350bhp it would be fine with the extra 50bhp. l would only be prepared to do it with genuine Land Rover software though. After bad experiences with remaps in the past. There is at least one company claiming to use genuine Land Rover software. Last edited by lightning on 12th Aug 2024 6:10pm. Edited 1 time in total |
