![]() | Home > Modifications & Maintenance (L663) > Tuning/remap d200 to d300 |
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 99 ![]() ![]() |
Trust me... if they notice that ANYTHING has been changed with the motor, then they will refuse warranty cover!!
It doesn't matter if you have used the Genuine remap or if you have used a aftermarket remap!! I know this because I have a D5 that had the DETUNED version of the TDV6 (150KW rather than 180KW). This is due to taxation. The engines are identical... it is just the tuning that is different. I asked my dealer if they could map it with the 180KW, and they said that "could" do it, but that it would invalidate the warranty. I then asked Alive Tuning, and they told me that they could also do it, but that each time the map is applied, there is a "counter" that increases... so the dealer can "see" if it has been modified. They also said that if it is "mapped" (even with the OEM files), that the vehicle RISKS losing warranty not only on the engine, but on the whole drive train (transmission, diffs etc) because LR will say that you are putting more power in to the components than JLR designed when then manufactured the vehicle. We all know that the engines are internally identical, but they don't admit that. So... I would think VERY carefully before mapping the engine while the vehicle is still under warranty because JLR will use any excuse they can to not pay out if they can!! |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3011 ![]() ![]() |
Changing a D250 to 350 takes two seconds off the 0-60mph time. Down from 8 to 6.1
So it's definitely worthwhile if you want more performance, (and your Defender is out of warranty) The engine/transmission etc should be fine as it's available with 350bhp in some versions. |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 305 ![]() ![]() |
although your brakes will still be different…. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
And who knows if your emissions levels will remain the same in the event of a future MOT? Defender 110 SE I6 D250 23MY
Modder Member Since: 29 Nov 2024 Location: Wuustwezel Posts: 17 ![]() ![]() |
Did the remap from D200 tot D300, and makes a very big differance for me. A D200 is not slow, but my 90 is now really a fun car to drive also on road, overtakes and short sprints are awesome.
Yes there will be a risk attached to it if you run in to issues, but so far i would not have it any other way |
Ub_r Member Since: 13 Dec 2024 Location: Ath Posts: 3 ![]() ![]() ![]() |
hi, i see there are some who are from belgium. could you tell me where you did the reprogramming? because everywhere i go i am told that for versions after 2021, it is still not possible… i need it because my egr valve is starting to act up….
snowtiger Member Since: 06 Oct 2022 Location: Bavaria Posts: 32 ![]() ![]() |
There are definitely more differences even in the engine. The D200 has for sure different pistons than a D350. Composition may be different, as more power needs to handle more heat. And as manufacturers try to save money wherever they can, they will equip a D200 with the cheapest possible piston composition. Regarding the spare parts, there is just the D350 piston available, as storage costs may exceed material costs, when they need to handle different pistons for different engines. That's why a lot of ppl think, engines are identical, because there is just one spare part number for pistons, rods, etc... |
Check DutchdefenderX on Instagram, he works with Hunter Prestige to do the upgrades in the BeNeLux |
ah ok, thanks! I'll have a look. Do you know if it also deactivates the EGR valve?
DutchdefenderX Member Since: 25 Dec 2024 Location: Amsterdam Posts: 4 ![]() ![]() |
Hi, yes i can remap d200 -> d300 and my25 to d350
Also for the p300e -> p400E I do this as a partner from Hunters Prestige. For benelux region. Takes between 1 and 2 hours for a propper remap with original hardware (doip) and landrover software and extra safery precautions with the battery (no brick risk) I will not do anything with the EGR valve. For inquiries, dm me on my instagram account. Dutchdefenderx This is my defender ![]() Click image to enlarge |
